Primary leak
Old Aug 10, 2011 | 06:10 PM
leadtheway's Avatar
leadtheway
Default Primary leak
Hey all, newbie here. Just bought my first harley a few months ago, its a 2004 sportster 1200 custom, been running fine then one day i came out to the garage and had a few spots under the bike, there was a drop of fluid on the primary drain plug, i could also see fluid on the whole left side. But i thought maybe it was the o-ring on the plug, so i replaced that and changed my fluid while doing it, took it out for a test came back, still fluid..this time it looked like it was leaking from the bottom of inspection cover, bought new gasket and screw o-rings. still leaking, cleaned up all spotless, took for another short ride, and it looks to me like its coming from where the shifter goes into the primary cover? i see a black seal, could this have gone bad? and is it a hard DIY?
thanks in advance
Old Aug 10, 2011 | 06:54 PM
woodsytattooman's Avatar
woodsytattooman
They do go bad.You can get one for about 3 bucks.Just remove the shifter,Take the old seal out with a small screwdriver,Clean the seal seat out good with rag or something.Put new seal in,replace shifter.I done mine in about 10 mins.Some people say they use and o-ring but i went with the seal.Yea the seal comes out from the outside so you don't have to remove the cover again.
Old Aug 10, 2011 | 07:00 PM
HarleyScuba's Avatar
HarleyScuba
A dental pick works nicely to dig out the old seal after the shift lever has been removed. Set the new seal in with the appropriate size deep socket (might need a metric size, iirc) and a light tap with a dead blow hammer.
Old Aug 10, 2011 | 07:28 PM
leadtheway's Avatar
leadtheway
thanks for the replies guys, what's all involved in removing the shifter, can it be done without removing the primary cover?
Old Aug 10, 2011 | 07:46 PM
woodsytattooman
Yes.Just one nut and remove the bolt.You may have to pry the shifter apart a little with a screwdriver while working it off.Try to avoid prying against the primary cover if you can.A little shot of lube may make it easier to get off.
Old Aug 10, 2011 | 08:31 PM
HarleyScuba
Originally Posted by woodsytattooman
...and remove the bolt.
+1
You must completely remove the bolt. The shift shaft has a groove that retains the lever if the bolt isn't removed.
Brandon Rannow
Oct 28, 2020 02:10 AM
BuckeyeUltra
Aug 7, 2014 07:59 AM
YellowHawk
Oct 1, 2009 07:42 AM
HoolyNI
Aug 24, 2009 04:03 PM
tattoo13
Jul 7, 2008 04:56 AM
