Baffle mod
Old Aug 15, 2011 | 08:06 AM
sgw1064's Avatar
sgw1064
Default Baffle mod
I installed some quiet baffles and it did not quiet my V&H pipes like I wanted. The baffles came with insulation wrapped around 3/4 of the baffle. I removed them and insulated the rest of the baffle. This sounds a lot quieter idling and sounds good high RPMs.also bike runs good. My question am I possibly blocking exhaust by adding this additional insulation? If so will this damage engine? Thanks
Old Aug 15, 2011 | 08:38 AM
ezmo's Avatar
ezmo
No. If you think how much does OEM mufflers block the exhaust. Yours is now in good shape.
Old Aug 15, 2011 | 08:55 AM
sgw1064's Avatar
sgw1064
Thanks
Old Aug 15, 2011 | 09:59 AM
XL50#674's Avatar
XL50#674
Yes your engine will only last a few hundred miles now LOL! I say take the baffles out and run it right!
Old Aug 15, 2011 | 08:00 PM
goinboardn's Avatar
goinboardn
May be a silly question, but I too would like to quiet my quiet baffles, what did you use as insulation?
Old Aug 15, 2011 | 08:35 PM
sgw1064's Avatar
sgw1064
Actually got it at dealer for under $10 its white about 3/8 thick and feel like dense insulation friend told me i could use fiberglass insulation
Old Aug 15, 2011 | 08:59 PM
HarleyScuba's Avatar
HarleyScuba
https://www.hdforums.com/forum/sport...ml#post8258953
"It's an easy mod that can accomplish a couple of pluses other than just a quieter ride... it also gives the V&H a deeper rumble and a better air flow and back pressure. Go to www.mcmaster-carr and click on ceramic fiber, scroll down to silica fabric, and buy 1 foot of SKU 8799K3 @ $9.26 plus $4.39 shipping... total $13.65. The 1 foot is 3 feet wide so there is plenty of fabric to double wrap each baffle.
You can't just use fiberglass... it "wears" or "burns" out over time. The new ceramic silicas will last the lifetime of the bike and are easier to install."
Old Aug 15, 2011 | 09:22 PM
jpollard62's Avatar
jpollard62
I used the Quiet baffles also but it was still a little loud on long trips. It still had that drone sound. I added the "SmartPartz" baffles in addition to the V&H quiet baffles. Drone is gone which makes long trips nicer. It still gets loud if you get on it but it makes the bike nicer. You may lose a little power but to me it is worth it.....Just my two cents...
Old Aug 16, 2011 | 12:50 AM
goinboardn's Avatar
goinboardn
Thanks for the info! I placed my order @McMaster-Carr. I am sure my neighbors will appreciate any reduction in sound.
Old Sep 23, 2011 | 01:56 PM
TXSailor's Avatar
TXSailor
goinboardn - Did you get your cloth and get the baffles wrapped yet???
Curious as to your results as I just ordered form McMaster yesterday so i can try wrapping my V&H Staggered Big Shots that have the "standard" (straight through - not the quiet baffle) in them.
D.
