Finally, your injected HD can have it the traditional and respected idle of a real motor carbureted.
The new SE Idle Control can be installed on any HD that has control idle control realized through IAC (can not be installed in an engine which is maintained by throttle body butterfly entry).
The installation of the new SE Idle Control is extremely simple. A wiring harness with 4 points connector is connected to the IAC in place of the original connector. The button to adjust the
Idle is placed on side of the bike, at the end of the tank ,so that it has easy access with the fingers of his left hand. Two terminals that are connected directly to the battery finish the installation.
Ready! Is installed and running!
The originality of the bike is not altered and the installation is 100% reversible. No important part is removed or replaced.
nice! Where'd you get it and approx how much did it run you? How long would you estimate that it took you to install?
Oh, and do you have more pics of the chick with the pretty yellow nails
I got it from a dealer in Madrid Spain. Final price was 220 Euros, installation took me about 30 minutes but can be done in 20.
Thanks for your compliments to my daughter, yep, she's pretty and nice!!!
