Pipe burns.
I keep rubbing the heal of my shoe on the side of the pipe.
It is only about an area about six inches long.
Does anyone make a heat shield that bolts on in some manner
or is wrapping the pipe the only way to do it??
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Mufflers ones:
Got home and realized my pants leg had blown up between the heat shield and the pipe---silver dollar size hole in the new jeans--guess my pants were that "pretty stinkin trash"
Pyrogel is rated for 1200F so I do not know yet how long it will last - it has tanned on the pipe side after 3 days. Do not have a thermometer to measure the temp's yet. Cost was low $35 for a 12" x 12" sheet that is just enough for both shields. I plan to put another layer under the cylinder end (upward) section vs putting any under the front cylinder shield which is not near my leg.
BTW, I found my rear stock pipe belt/engine case holding bracket cracked through. I have seen a few other posts on this. I plan to put some of the Pyrogel under its connecting pipe clamp to absorb some of the vibration & heat for a fix. I saw a post that said this bracket/clamp is needed to keep header bolts from loosening. Anyone know if the clamp is really useful?
