Adding a tachometer?
Old Oct 27, 2012 | 08:23 PM
hhkiwi's Avatar
hhkiwi
There are two main options to add a tach:
1. You can purchase a tach/speedo unit from HD or Dakota Digital; or
2. You can get an aftermarket tach, e.g. from Ebay or Amazon.
If you buy an aftermarket tach, make sure it is suitable for two cylinder engines and has an inductive pick up.
Old Oct 27, 2012 | 10:20 PM
dwagar's Avatar
dwagar
If you just want a small tach, have a look at the Microtach from Speedway instruments.
Old Oct 28, 2012 | 11:47 AM
BaldHOG1222's Avatar
BaldHOG1222
Dakota Digital 3204......love mine. Gives you a bunch of other cool info too. You can pick one up on eBay for around $320. Plug and play
Old Oct 28, 2012 | 04:41 PM
Devils Cut's Avatar
Devils Cut
I also would love a tech the one I want is H-D factory tech. It's around. $ 285.00 plus tax. And I sure it's a PnP as well. But my question would be are they a useful add-on? I personally know when to shift. Or is it some else just to say " mine has a tech ". Just wondering.
Old Oct 29, 2012 | 02:19 AM
Dual-Linkerts's Avatar
Dual-Linkerts
Originally Posted by wanabe
i have a hot right hand and still have never hit the rev limiter... some day i will.
my advice, think twice before adding that tach. if you ever use it, you shouldnt (unless you are on the track)!
I agree you don't need a tachometer since your bike already has a built in rev- limiter.
The only advantage I could see to adding a tach to my bike would be to let me know where to shift Before the rev-limiter kicks in which happens more than I like.
If i was able to bypass the limiter entirely then a tachometer would definately be needed.
Old Oct 29, 2012 | 11:12 AM
Roni's Avatar
Roni
My '01 1200 XLH came with the tach already installed. While HD doesn't show one for the 1200, it does have one for the 883. I'm pretty sure that's the unit that's on the bike.
I added the tach/speedo combo unit to my '07 XL1200C. In order to get it into the house, I had to remove the handle bars from the mount. The hardest part was installing the optional gas gauge. Also, there's no gear indicator. I think both of these features might be standard on the '08s and later, so you would only need to add the guage.
While I don't use my tach at every shift, there are times when I do look at and want that information. While I suppose that I could live without it, every bike that I've ever owned had a tach as standard equipment, so I've gotten used to having one.
JoeHat
Feb 21, 2011 04:01 AM
Riderx2
Jun 25, 2009 08:20 AM
69cuda
Mar 13, 2009 05:59 PM
sturgis kidd
Apr 7, 2006 09:16 AM
1200c
Jul 12, 2005 03:02 AM
