rocker box bolt oil leak...is it possible?
Old Nov 12, 2011 | 06:01 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
just tried metal polish and it's not coming out...at least i didn't fuct it up worse...really sucks, she's brand new...and i don't have a cat but there are a few around so it's possible...
Old Nov 12, 2011 | 06:31 PM
CosmoKramer's Avatar
CosmoKramer
Originally Posted by SpicOfTheDevil
oil seems to have come out from the one of the rear rocker box bolt...when i noticed it was already dry, so i assume it was oil...is this possible?
Doesn't really look like oil but just to point out that there are fiber washers gaskets under each rocker cover bolt / washer.
Old Nov 13, 2011 | 05:11 PM
fixedmlc's Avatar
fixedmlc
Try bug & tar remover but stay with it, don't let it run anywhere off that rocker box. First try put it on and take it off fairly quickly and see if it makes a difference, if it does, put it on again and let it sit and work its' magic.......
Old Nov 13, 2011 | 05:14 PM
fixedmlc's Avatar
fixedmlc
After looking closer, that stuff looks somewhat like it ate into the clear coat on the aluminum, you didn't happen to use any brakleen on anything in that area did you? That stuff eats the clear coat right off aluminum.
Old Nov 13, 2011 | 07:00 PM
editbrain's Avatar
editbrain
If it isn't bird poop. I was thinking brake fluid or something. Like I was saying. My front brake cylinder gasket started leaking at around 80 mph.
Got everywhere on the trees, bars, rocker boxes, tank.
It came of the tank without spotting, but the boxes and trees were bad. I took Never Dull (i think what it was/is called), and rubbed it with microfiber forever, and then whipped it off. Then used Windex to clean the trees.
The boxes took a buffer wheel on a variable drill and aluminum polish to get the pits out. It worked, but it was rough. I took it slow with white brick, and finished up with red. Then I used the Never Dull. They turned out like new. Just like nothing was ever there.
Old Nov 13, 2011 | 07:14 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Mine leaks from the bolt because it was over tightened and stripped.
Old Nov 13, 2011 | 07:17 PM
SpicOfTheDevil
had used only water before it appeared...yesterday tried mother's wheel polish, aluminum safe, and didn't come off...the positive is that no one thinks it' oil...i keep reminding me it's a material thing but i work damn hard and put up with a lot sheeet to be able to afford her...thanks everyone
DEG147
Sep 3, 2016 09:42 AM
HarleyGTP
Aug 17, 2014 04:18 PM
liquidr1
Aug 6, 2013 02:33 PM
marine_hm@hotmail.com
Sep 15, 2012 12:41 PM
Scudda
EVO
Jul 7, 2012 11:21 AM
