Need help please!!!!!!
Old Nov 17, 2011 | 11:40 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Like I said in post 10 so you would not damage starter but oh well. Now squirt a good oz of liquid wrench in both spark plug holes. let it sit a good 24 hours. Then an oz of oil in each. Now if you do not have an axle, remove chain and turn sprocket with a strap wrench or whatever you can get a hold of it. (all the while with plugs out)
I assume your trying to save bucks. As long as it's not too rusty it will come back. I would consider worst case overhaul but thats' just me , you can get it running as is.
Old Nov 18, 2011 | 08:27 AM
vyper73's Avatar
vyper73
i think starter is still ok but was thinking of replacing it anyway....safe then sorry I was told mystery oil would be best....any thoughts? and yes saving bucks is my prefered option lol
Old Nov 18, 2011 | 08:39 AM
cavalier2000's Avatar
cavalier2000
Usually older people swear byte mystery oil. In your case any lube is better than none
Old Nov 18, 2011 | 02:19 PM
vyper73's Avatar
vyper73
Funny you should say that....It was a older guy that swore by it at our lodge last night....lol
Old Nov 18, 2011 | 02:40 PM
rickss69's Avatar
rickss69
Nothing better than ATF to break one loose...no side effects either.
Old Nov 23, 2011 | 08:52 AM
vyper73's Avatar
vyper73
Well she lives....Kinda.....I rotated it by hand after shooting it with PB Blaster.....and i applied power to crank it minus the plugs and it rotated full revolution then I think starter died...all I hear running with power is the starter solenoid..... any suggestions?
Old Nov 23, 2011 | 11:40 AM
cavalier2000
Like your starter is shot? You can tap it with a hammer lightly and see if it will kick over. Just keep lubing it up till you get it running.
Old Jan 6, 2012 | 10:40 AM
vyper73's Avatar
vyper73
Default Reassembly time
Ok all i have started reassembling it.....Man what a pain in the **** lol
I have 2 questions....
1. can I convert the points to EI and
2. Is it normal for the front wheel to be 19 and the rear 16?
Also found out that this isn't even the original frame Argggggg! Lol
Old Jan 6, 2012 | 10:48 AM
cavalier2000
Yea those are normal rim sizes
Old Jan 6, 2012 | 10:51 AM
WVHogRider's Avatar
WVHogRider
Yes, Sporties come with a 19" or 21" front wheel and a 16" rear.
