WTF!?! Idle Question
Old Feb 25, 2012 | 02:08 PM
emperor wurm's Avatar
emperor wurm
Default WTF!?! Idle Question
My 2000 sporty 1200s is having problems with the the idle. I set it between 950 and 1050 with the motor warm. After about 15 minutes of riding the idle shoots back up to 1500. I thought it might be a vacuum problems, but i pulled the carb and everything is in order, lines are clean no cracks or unattached hoses.....any ideas?
Old Feb 25, 2012 | 02:37 PM
chappy99's Avatar
chappy99
Set it about 1050 when hot,then use your star wheel to keep the rpm's up tell she
gets warm.
Old Feb 25, 2012 | 02:57 PM
emperor wurm
do you think the enrichiner screw has anything to do with it? or is that just for the choke?
Old Feb 25, 2012 | 03:57 PM
chappy99's Avatar
chappy99
I just use the choke to get the bike going,maybe after the bike starts half way for 30 secs
then use the star wheel to keep the bike around 1200 tell it warms up.
If i set my idle before the bike is hot when it gets hot my idle is way to high like yours.
1997 sportster
Old Feb 25, 2012 | 04:41 PM
emperor wurm
thanks man!
Old Feb 25, 2012 | 04:54 PM
chappy99's Avatar
chappy99
Glade to help
Old Feb 25, 2012 | 09:13 PM
navd's Avatar
navd
this could still very well be a vacuum leak. To shoot up 500rpm sounds most definitely like one. Sources: Been there done that.
navd's Avatar
navd
The leak doesn't have to sit behind the carb either but could be between the intake manifold and heads.
Old Feb 25, 2012 | 09:36 PM
Imold's Avatar
Imold
You could spray a little (very little, don't want to hose a hot engine) water over the intake manifold joints, or WD40, which I've been told also burns like starting fluid, so your rpm's will jump if there's a leak. It's negative pressure in the manifold (I'm guessing you probably know that, maybe someone reading won't) so anything you spray will get sucked in, but momentarily stop the leak before it does. If the rpm varies either way when you spray, there's almost certainly a leak. Bit different engine, but when my 883 goes off choke, it doesn't idle any faster as it gets hot.
RollingBurn
Apr 13, 2015 06:25 PM
emperor wurm
Dec 8, 2011 10:08 PM
sportster77
Ironhead
28
May 28, 2009 08:30 PM
chrism84
Exhaust System Topics
Apr 4, 2007 07:36 PM
500MAG
13
Mar 29, 2007 10:19 PM
