Burly Clutch Pull
Old Apr 2, 2012 | 12:25 AM
odie-in-az's Avatar
odie-in-az
Default Burly Clutch Pull
Has anyone else had a problem with the Burly Clutch being really stiff, and especially hard when releasing the clutch while taking off from a stop? When I release the clutch to engage,he throttle the clutch is not smooth, and I have to release the lever in stages making my primary to jerk. I have tried lubing the cable with Inox and I have made all proper adjustments. Thanks for anyone's input.
Old Apr 2, 2012 | 01:26 AM
odie-in-az's Avatar
odie-in-az
I found a thread that hits on this. Something about the nylon coating binding. Gonna check it out.
Old Apr 2, 2012 | 10:31 AM
barrygreen's Avatar
barrygreen
It will get better, mine had a creek when pulling in, went away. I also had the same issue your talking about at first, but not now...give it time.
Old Apr 4, 2012 | 10:52 AM
DravenGSX's Avatar
DravenGSX
I took the Burly cable, threw it across the room and then installed a cable from Drag Specialties.
The Burly cables are junk.
Old Apr 4, 2012 | 10:47 PM
odie-in-az's Avatar
odie-in-az
I put some white lightening in the cable housing. The release was so stiff that the primary was jerking and clanging when I tried to take off. The white lightening has improved the function quit a bit and I'll give it a little time like you suggest.
Old Apr 4, 2012 | 10:49 PM
odie-in-az's Avatar
odie-in-az
I've had bad experience with drag specialties throttle/idle cable and I think their cables are junk. HD actually has some of the better cables in my opinion. If the Burly doesn't work I'll spend $40 on a HD cable.
rick775472
Jul 5, 2015 09:08 PM
dick fitz
Oct 31, 2014 09:19 AM
rdondes
Oct 23, 2013 08:16 PM
Jonesee
Sep 30, 2013 09:39 PM
CT-Bagger
Oct 7, 2012 09:53 PM
