help
Old Apr 17, 2012 | 01:13 PM
knights's Avatar
knights
thanks for the link n thanks for the answer. your all awesome
Old Apr 17, 2012 | 01:56 PM
guitarman023's Avatar
guitarman023
yeah, sorry about that. SAE = Society of Automotive Engineers. Here's a link on how to use taps and dies. Not only do they clean threads, they also make new threads and allow you to make your own parts.
http://www.youtube.com/watch?v=j8m1F5ObOQI
Old Apr 17, 2012 | 02:08 PM
knights's Avatar
knights
ah thankyou so much for the link.
so are you saying that its possible to convert an SAE thread to a metric size thread?
or will it just make a sae bolt thead into a smaller sae thread
Old Apr 17, 2012 | 02:33 PM
guitarman023
yeah, you can convert them, you usually have to start by drill the existing threads out though and bumping up to a bigger size. Making bolts smaller is a pain without a lathe, it's just easier to tap threads and then use the correct bolt.
Old Apr 18, 2012 | 11:57 AM
knights's Avatar
knights
thanks guitarman
Old Apr 18, 2012 | 05:19 PM
mrfikser's Avatar
mrfikser
you might try and take a nut and cut a slit through one side with a dremel and a cut off blade so it looks like a "c" but with the 2 ends almost touching (try and find a nut with a shoulder on it)...and try and thread that onto the stud with a deep socket holding it as straight as you can..that may clean up the threads enough to get a couple of good nuts on the stud, which you can tighten together so they lock....then you can just turn the stud out with the nut
Old Apr 20, 2012 | 03:05 PM
knights's Avatar
knights
thanks for all the help guys, but iv give up and handed it over to a friend who is a lot better at stuff like this, he should get around to looking at it tomorrow
fingers X'd
CapeGlide
Aug 3, 2014 10:52 PM
BuckeyeUltra
May 6, 2014 08:04 AM
lanceropolis
Dec 12, 2009 06:44 PM
chunks
Jul 2, 2009 05:21 PM
urdollar
May 27, 2008 02:42 PM
