the one thats on the speedo that is..
mine seems to be on whilst im riding anybody know why?
otherwise it acts normally when bike switched off etc..
thanks..
my key light comes on while i'm riding too, I just made a mental note to block it out of my mind, just like how I blocked that my dad was a male nurse.
Had the same thing happen to me a few weeks ago. It turns out the front right directional reflector came loose causing the hot bulb to burn right through the amber bezel. The bulb then burned out causing the red key light to come on. Once the bulb is replaced, you have to clear the DT code. The key light will then stay off. I had to order a new amber bezel. By the way, the front directional bulb number is #191 which I found at Autozone for $1.98. The standard auto bulb # 1157 can be used as a replacement for $1.05, it's not as bright as the 191 bulb though.
i only have my rear turn signals wired in at the moment i suspect when i wire the front ones in it will be ok (whats a DT code?) thx
DT code is Diagnostic Code that is retrieved from speedo by holding in reset button on speedo and then turning ignition key to on. HD service manual has good right up on reading codes and resetting them.
There is a great write up in the stickies on the first page of this forum. Sorry for not mentioning in last post. I also spell better when I slow down...right up verses write up!
is it normal that the red light key turns on it you drag your bike without starting it up ?
cz that is happening to me each time since i have installed SE exhaust and they are loud
so i have to drag it out f the garage before starting it otherwise the neighbor will kill me
