Summer Switch-Up
Old Sep 8, 2012 | 08:12 PM
  #81
tripn88's Avatar
tripn88
i just got tired of running wires i changed my bars so much i just relocated switches lol
Old Sep 8, 2012 | 09:05 PM
  #82
streetfighter06's Avatar
streetfighter06
So what did u do about ur throttle housing?
Old Sep 8, 2012 | 09:15 PM
  #83
tripn88's Avatar
tripn88
I just got your email.
I used the biltwell whiskey throttle. Its a pretty sweet product, a little pricey but its all aluminum solid construction. I got the single cable one but they have dual cable if you prefer that. Im not done with everything i need to round off the lip on the Brake M/C and cut a little off the bar to fill that gap.
I hear there are some cheap plastic ones on egay but iv also heard they dont last that long. As far as mounting your switches somewhere Im not sure where to I took the easy route and mounted them behind the HD Visor. I have a momentary for the start and horn, then a two pole toggle for the kill switch and a 3 pole toggle for headlight low/off/hi.
if you need anything just let me know and ill do some brain storming for ya.
(edit) if you go with the whiskey throttle youll have to get a banjo bolt brake switch. The rear still works but the brake light switch has nothing to sit in for the front brake.
Old Sep 8, 2012 | 10:45 PM
  #84
madchemist24's Avatar
madchemist24
Originally Posted by streetfighter06
Hell yeah! Thanks for the encouragemnet, buddy! I'm gonna defeat this ****!!!! No Prob!
These will be easy. I got mine thru double 45° angles ... thise were a bitch.
Old Sep 8, 2012 | 10:53 PM
  #85
streetfighter06
Still cant do mine......
Old Sep 9, 2012 | 12:42 AM
  #86
run1fsr's Avatar
run1fsr
omg internally wiring these bars is ****ing impossible.....
I Feel Your Pain.
Old Sep 9, 2012 | 08:23 AM
  #87
samhallnc's Avatar
samhallnc
I tried several things and failed before I figured out what worked.. for what it's worth this is what worked for me-
I took some fly fishing string and tied knots in it every inch or so, then taped that with the bundle of wires as tight as i could wrap it (with rigging tape so it wasnt a sticky mess).. then sprayed the bundle with cooking spray.. pulled through easily.
Old Sep 9, 2012 | 09:53 AM
  #88
bmxatv's Avatar
bmxatv
Old Sep 9, 2012 | 10:50 AM
  #89
Rog48's Avatar
Rog48
One thing about Bills bars (where I got mine), he makes sure internal transitions are smooth so the wires wont hang up as much going around the bends. Maybe thats why mine went so easily.
Old Sep 9, 2012 | 11:35 AM
  #90
streetfighter06
Now i got my throttle stuck and idk why..... Losing my patience.....
