Tire Issue
Old Sep 19, 2012 | 05:24 PM
JDSporty's Avatar
JDSporty
Default Tire Issue
Decided to go for a ride after work. Noticed tire was flat. Found a tiny puncture. Nothing in it. This tire only has a few thousand miles on it. Can a motorcycle tire be plugged? Is that safe? Hate to throw tire away. I guess i have been lucky, never had a flat tire on a bike before.
Old Sep 19, 2012 | 05:40 PM
Brion B's Avatar
Brion B
Most do not recommend plugging a motorcycle tire but I have done it in the past with no problems.If you have a laced (spoked wheel)you can patch or replace the tube.
Old Sep 19, 2012 | 06:32 PM
Dual-Linkerts's Avatar
Dual-Linkerts
Try airing it up and see how fast the leak is if its a slow leak ride it to a nearby cycle shop and let them patch it the only time I would use a plug is out on a road trip for emergencies.
Old Sep 20, 2012 | 04:44 AM
grbrown's Avatar
grbrown
Good advice from the other chaps. A vulcanised patch inside the tyre is the best repair for tubeless, or a patched/new tube. I agree about plugs being temporary, but if I was on tour and had to use one, and it held up, I don't think I would have any qualms about riding thousands of miles on one!
Old Sep 20, 2012 | 05:50 AM
WVHogRider's Avatar
WVHogRider
Been running a plug in my tire for several thousand miles on my rear tire, but I have the tubeless mag wheels. As others have said, if it's a spoked wheel, replace the tube and have the tire patched from inside.
Old Sep 20, 2012 | 06:38 AM
cHarley's Avatar
cHarley
I have no problems using a plug if it's done right, but vulcanized patch inside the tire is better.
If you have tubeless tires (cast wheels), you can still put a tube in it in addition to the plug/patch for extra safety.
If your going to plug tires, this type of mushroom plug is the best plug for the job.
Amazon Amazon
Griff012FLHX
Sep 19, 2014 09:43 PM
mtnbikerx
Mar 11, 2009 08:59 PM
archermatt
May 12, 2008 06:13 AM
Numbawon
Oct 26, 2006 10:48 PM
kingultra
Oct 2, 2006 05:33 PM
