Excess vibration after installing spoke rims/new tires
Old Sep 24, 2012 | 05:43 PM
RedTailChop's Avatar
RedTailChop
Default Excess vibration after installing spoke rims/new tires
I just got a set of spoke wheels with brand new Shinko tires installed. I am getting excess vibration at high rpms right before you shift. What could be the problem? I was thinking it could be the belt, not quite sure where I should start looking.
Old Sep 24, 2012 | 05:58 PM
Von_Zipper's Avatar
Von_Zipper
Considering all the information you have provided it may be the muffler bearing.
Old Sep 24, 2012 | 06:08 PM
RedTailChop
Well it does not have stock mufflers. I have vance and hines radius installed. Where is that located?
Old Sep 24, 2012 | 06:15 PM
Brion B's Avatar
Brion B
It is not your muffler bearing,he is pulling your leg.Maybe one or both of the rims are not balanced properly.
Old Sep 24, 2012 | 06:19 PM
Von_Zipper's Avatar
Von_Zipper
How can rim balance affect vibration caused by RPM?
Old Sep 24, 2012 | 06:28 PM
Brion B's Avatar
Brion B
Well, I guess if it could be a muffler bearing, it is also possible that it could be rim balance, especially if the rims and tires were just changed before the problem started.
Old Sep 24, 2012 | 07:03 PM
Von_Zipper's Avatar
Von_Zipper
Right, just look at the initial posting.
Vibration caused by wheels will depend on speed, not RPM. And this
is even more confusing. I do know when I shift. How can it cause vibration on his bike?
Old Sep 24, 2012 | 08:28 PM
Judge1989's Avatar
Judge1989
Check belt tension and alignment per your service manual.
Old Sep 25, 2012 | 09:39 AM
1984_FXRT's Avatar
1984_FXRT
Also check the security of your engine mount bolts. Is this a solid-mount or rubber mount XL?
Old Sep 25, 2012 | 08:10 PM
RedTailChop
Rubber mount
X90
Sep 10, 2011 05:22 PM
dortiz
Wheels/Tires
Aug 17, 2011 09:55 AM
windix60
Jun 19, 2011 11:09 AM
Scooter68
May 25, 2010 04:44 PM
clucker
Dec 5, 2009 02:36 PM
