How to remove this cover??
Old Oct 25, 2012 | 06:22 PM
cegd_2000's Avatar
cegd_2000
Question How to remove this cover??
One of my front turn signals is loose and I'm trying to adjust the screw that holds it in place, but my problem is that I found a piece like a cover of that screw and I don't know how to remove it.
Anyone knows how can I do that?? Actually I broke one of the two covers trying to remove it.
My bike is a 2012 Sportster 1200 Custom.
Here are some pics of that part
Thanks
Old Oct 25, 2012 | 06:36 PM
John Harper's Avatar
John Harper
I'm just guessing, but I think if you take off the lower clutch handlebar clamp (or whatever the light is attached to), there will be an allen or torx head screw that goes into that light housing. That short piece of metal around the screw is just a spacer.
I have no idea what that cap-like thing you broke off is for, my bike has nothing even close to looking like that, it's an older model, 1991.
I know my lights up front are externally wired, so my mount on the forks was just a long screw, and the hole in the spacer piece to attach it to the fork pinch bolt. I could be totally wrong about this.
Old Oct 25, 2012 | 06:38 PM
Knights2TheEnd's Avatar
Knights2TheEnd
Looks like a very small allen socket
Old Oct 25, 2012 | 06:46 PM
John Harper
Pretty small for that size bolt (or whatever it is). It almost looks like he broke off a tiny threaded screw that that cap was attached too, so maybe a small allen is possible. But what the heck is the function of the metal piece it's attached to? And why such a weird design?
I got no idea.
John
Old Oct 25, 2012 | 11:09 PM
Knights2TheEnd
I got no idea.
John
Yea seems like a worthless piece with no function, my bike does not have these covers. does the other side of the cover have a thread? Or any notches? You should be able to tell how to take off the second one by looking at the configuration on the back
Old Oct 25, 2012 | 11:11 PM
MrCookie's Avatar
MrCookie
Looks like a rivet to me
Old Oct 26, 2012 | 04:28 AM
Sportabagger's Avatar
Sportabagger
[QUOTE=MrCookie;10483959]Looks like a rivet to me[/QUOTE
We have a winner , drill it out
Old Oct 26, 2012 | 03:00 PM
cegd_2000's Avatar
cegd_2000
[QUOTE=Sportabagger;10484309]
I think I'll do that
Old Oct 26, 2012 | 04:04 PM
John Harper
[quote=cegd_2000;10486130]
I think I'd figure out what it is and does before hitting it with a drill.
John
Old Oct 27, 2012 | 12:35 AM
Gpsjr10's Avatar
Gpsjr10
If it is a cover or whatever I am not sure about that, but behind it should be a small Allen set screw and that holds the light in place. On the end of the shaft is a ball end that allows you to adjust the position of the light, the set screw tightens down on that ball. The shaft should simply screw into the light housing.
