ape problems
Old Nov 8, 2012 | 12:14 PM
Afrobaron's Avatar
Afrobaron
Originally Posted by samhallnc
That makes sense. I've been hesitant to try any of the sandpaper / aluminum solutions people have offered because I don't understand how it would work.. rubber makes sense to me. I'll give that a shot.
The sand paper and aluminium trick must work by increasing the diameter of the bar. That should allow the clamp to provide a tighter squeeze overall.
The rubber does essentially the same thing but also would provide a common surface for the bars and clamp to grip that would be less prone to slip than the other two.
Old Nov 9, 2012 | 05:51 PM
jag1886's Avatar
jag1886
Originally Posted by chappy99
You can take a sharp center punch and make 7 or 8 lines of marks on the handle bars that will not be seen when the clamps are in place,that will work the same as being knurled.
This works a 100% of the time. Make good deep dents when doing this, it raises the metal around the dent. I did this on my last 2 sets of apes and no more moving. Don't wrap crap around the bars or try and shove something in between it won't work and will fail at the most inopportune moment.
soulpatch
Jun 29, 2021 07:01 PM
wyotana
May 30, 2020 04:59 PM
stbobshadow
Jan 27, 2015 01:53 AM
blackknight883
Apr 30, 2013 05:35 PM
hobo1
May 6, 2012 06:52 PM
