Xl1200l
Old Dec 8, 2012 | 03:56 PM
Kenjr's Avatar
Kenjr
Default Xl1200l
Recently bought my wife a 2009 1200 Low. Curious what changes are made to the bike from a stock height XL1200, besides the seat.
Thanks
Ken
Old Dec 8, 2012 | 04:02 PM
ev0lution7's Avatar
ev0lution7
Short suspension... Other than that its a reg 1200
Old Dec 8, 2012 | 04:32 PM
grbrown's Avatar
grbrown
Shorter shocks and front forks.
Old Dec 9, 2012 | 06:49 PM
Kenjr's Avatar
Kenjr
Thanks for the replies, do you know if the forks are actually different or have a lowering "kit" of some sort.
Old Dec 9, 2012 | 07:39 PM
jkinner's Avatar
jkinner
Front tire is different from the C (fatter)the forks look the same to me but i could be wrong.
I used the full 3" spacer on mine when replacing the fork springs with Progressives,
The low has a differrnt set of risers and speedo mount,mid controls, and MHO the
stock seat is almost useless. I have had mine sinse new with no problems.
09 1200L.
Old Dec 9, 2012 | 07:58 PM
HarleyScuba's Avatar
HarleyScuba
The front fork tubes, fork springs and damper tubes are different in the factory C vs L models. The lower legs are the same.
The C has a 21" front wheel and the L has a 19". The tires have different sidewall ratios resulting in two assemblies with darn near identical diameters overall. The front fenders are the same.
Old Dec 10, 2012 | 03:12 AM
grbrown's Avatar
grbrown
As Scuba said, the sliders are the same, but chrome tubes shorter. Simplest way to check is looking at the microfiche at Ronnies HD website, to compare part numbers. I suspect the damper rods inside may also be shorter.
Old Dec 10, 2012 | 05:21 PM
Kenjr's Avatar
Kenjr
Thanks for the replies.
Ken
yoginibiker
Apr 4, 2012 06:06 PM
MechsHands
Mar 11, 2010 05:08 PM
Basz
Jul 23, 2009 10:49 PM
Piglet1999
Mar 17, 2009 06:09 PM
milkmann
Apr 7, 2008 04:42 PM
