Help, Constantly running out of gas
Old Feb 1, 2013 | 04:40 PM
dsearles1's Avatar
dsearles1
Stage I
Unhappy Help, Constantly running out of gas
I have a 94 sportster 883 with 900 original miles on it. Just replaced the petcock and had the carb serviced 3 months ago. Problem is I run out of gas in about 45 miles (2.2 gal tank) and can only go about 4 miles when switched to reserve. There is a strong smell of gas in the garage after riding and no visible leaks. Any thoughts as to the cause???
Old Feb 1, 2013 | 04:42 PM
Brion B's Avatar
Brion B
Sure does sound like a gas leak somewhere.
Old Feb 1, 2013 | 04:46 PM
streetfighter06's Avatar
streetfighter06
Evap problem?
Old Feb 1, 2013 | 04:54 PM
DrewBone's Avatar
DrewBone
From: In the foothills of southwestern NC - US of A
Honestly, that sure doesn't sound right, especially if you do the math; a 2.2 gallon tank gets you only 45 miles? Vapor smell in the garage with no visible sign of a leak?
Maybe your kid brother is stealing your gas for his crotch rocket?
=8^)
Old Feb 1, 2013 | 06:20 PM
tripn88's Avatar
tripn88
Is your tank venting properly? Maybe causing a vapor lock and fuel can't get to the carb. Is your float stuck open? How do your plugs look?
Old Feb 1, 2013 | 06:22 PM
Mathos883's Avatar
Mathos883
Wait quick question... do Irons have a reserve button switch also? (2013)
Old Feb 1, 2013 | 06:30 PM
tripn88's Avatar
tripn88
No you get a fancy light that looks like a gas pump. That means your using your reserve fuel.
Old Feb 1, 2013 | 06:34 PM
Mathos883's Avatar
Mathos883
Originally Posted by tripn88
no you get a fancy light that looks like a gas pump. That means your using your reserve fuel.
10-4!
Old Feb 1, 2013 | 07:31 PM
John Harper's Avatar
John Harper
Do you turn "off" the petcock when parked? I left mine "on" once and the tilt on the bike allowed gas to get past the float needle, with a full tank I would imagine there would be more fuel to exert pressure on float needle, JMO.
Is your accelerator pump diaphragm torn? You might be leaking fuel while riding and not even be aware.
Is your float level set correctly? Could be dumping out the overflow hose.
John
Old Feb 1, 2013 | 08:01 PM
Sensei Jim's Avatar
Sensei Jim
@ Mathos883 Don't count on the light. Mine comes on at about 90 miles. But people here say it varies alot. I go by mileage only. I try not to go past 120 but have pushed it to 140. I should get close to 150.
