What the deuce?
Old Feb 15, 2013 | 07:06 PM
prosport76's Avatar
prosport76
Default What the deuce?
My turn signals only blink while riding and for a short time after riding. While sitting the signals brighten but do not flash. What causes this?
Switched front & rear to led. Blinking is normal. Have no load equalizer installed.
I'm not looking for a fix, since they work fine while riding. Just would like for someone to explain why this happens.
Old Feb 15, 2013 | 07:54 PM
Deucedog's Avatar
Deucedog
I'm certainly not an electrical genius by any stretch, but here's my suggestion(s).
Check your wiring schematic and see where the single source of power is. Then check that source to confirm that it's getting the proper voltage at idle.
Do your other lights (head light, tail light, etc) also fade at idle? (possible regulator/stator problem)
Does it only do it if the brakes are applied at idle?
(possible short between the two circuits)
Old Feb 15, 2013 | 08:08 PM
prosport76's Avatar
prosport76
No other lights dim. I hooked up the two wire led lights with diodes and resistors in order to have running lights and blinkers. Got all the info from this site to do it.
Everything works great while and after riding for a minute. STRANGE Huh?
Originally Posted by Deucedog
I'm certainly not an electrical genius by any stretch, but here's me suggestion(s).
Old Feb 15, 2013 | 08:15 PM
Frostbite's Avatar
Frostbite
Best bet I can give without testing is the resistors are just a hair too big - if you were up here we could play around with it - I do electronics for a living.
Old Feb 15, 2013 | 08:19 PM
prosport76's Avatar
prosport76
Since everything works fine while riding.Even if the resistors are a little big. Will everything be OK?
Can anything be damaged?
Old Feb 15, 2013 | 08:27 PM
Deucedog's Avatar
Deucedog
I"m sure Frostbite has a more informed answer, but I'd say if it is a over sized resistor it wouldn't be a problem. At idle your bike doesn't put out full voltage so the resistor would be more 'resistant'. How's that for a technical term. lol
Old Feb 15, 2013 | 08:33 PM
prosport76's Avatar
prosport76
Sounds good to me. Thanks.
Frostbite's Avatar
Frostbite
Yeah, that works!
Old Feb 16, 2013 | 05:42 AM
grbrown's Avatar
grbrown
Red face
Your stock winker unit isn't designed to work with the very low electrical load that LEDs put on the system, compared with normal incandescent bulbs.
A Badlands or similar load equaliser will correct that. I did the same to my Glide and got strange things happening, but everything works fine with my Badlands.
ChaseDWG
Nov 13, 2018 08:47 PM
mtnroadking
Mar 17, 2013 03:19 PM
Hammer2284
Jun 12, 2011 03:05 PM
capt.rick
Ironhead
Feb 25, 2009 01:14 AM
rsofa
Mar 20, 2008 12:37 PM
