Gas cap vented or non
Old May 11, 2013 | 02:39 PM
RPG485's Avatar
RPG485
Default Gas cap vented or non
For my stock 1200 custom, if I were to race the stock gas cap do I need to make sure it's vented?
I have my eye on a flush mount pop up style cap
Old May 11, 2013 | 03:15 PM
JeffJA's Avatar
JeffJA
do you have the trim that run down the center of the tank on your custom?
if so, I don't think the pop up cap will work, oh..and im pretty sure they're vented caps.
Old May 11, 2013 | 03:17 PM
South JerseyJoe's Avatar
South JerseyJoe
I just got done putting a HD chrome flush mount on my 2012 C 1200. Love it! I believe all newer bikes are vented. Sure someone can chime in with dates. You don't mention your bikes year.
Old May 11, 2013 | 03:18 PM
RPG485's Avatar
RPG485
The trim has been removed for paint. I don't want to put the center trim on. I'm debating on using my stock cap without the trim or get the flush mount ones for a sleek look. Just needs to be sure it'll fit and or keep my stock ones
Old May 11, 2013 | 03:19 PM
RPG485's Avatar
RPG485
It's a 2008. Was it as simple as just screwing it in?
Old May 11, 2013 | 05:05 PM
South JerseyJoe
The whole cap screws out of existing hole just like a regular cap except no clicking when closed, just a snug down and that's it. Press down a little, turn just a bit and closed. Opposite for opening.
Only thing I could not figure is the ring is chromed plastic....go figure? I still like the pop up better than stock.
https://www.hdforums.com/forum/membe...t-gas-cap.html
Old May 12, 2013 | 02:21 AM
DOMAPOI's Avatar
DOMAPOI
I was always told they were unvented, that way if you lay it down it won't leak gas out onto the heads and start a fire.
Old May 12, 2013 | 01:34 PM
Pixiechitos's Avatar
Pixiechitos
If its EFI it's vented. So what's that guys? 2007/2008?
You'll know it's vented because the cap is so complex, all that plastic stuff and clicking stuff.
The non vented caps are pretty much just screw on.
I fitted a vented mooneyes cap.
Rocking_it
May 12, 2018 12:11 PM
Ashnic
Aug 22, 2016 09:29 PM
cbaywolf
May 8, 2014 05:41 PM
Low E
Oct 28, 2008 05:02 PM
LOTHAR
Jan 11, 2006 11:54 PM
