starting problems
Old May 20, 2013 | 02:27 AM
Judge1989's Avatar
Judge1989
Default starting problems
Hey Guys!
So my 94 sporty 1200 is being a little c***. Basically on the way to work today there was a loud whining noise coming from the bike along with what sounded like grinding. I pulled in to work and shut the bike off. I did not see any damage externally so I tried to start the bike again. To my surprise as soon as I turned the key the bike cranked and fired. I do not have any of my switches disabled (besides turn signals) So this was "neat". The noise was gone so I went in to work. When I came out from work same thing, Start with the key not with the switch. No noise so no worries right?
I stopped at the gas station to grab a pack of smokes next to my house and when I came out the bike won't start. Headlight comes on. Showing 11.9v with key in running position. Starter switch doesn't start bike, However with the key off the starter switch will turn on the headlight when I push it. Cool right??
Anybody else have a possessed bike and want to share some thoughts?
-Judge
Old May 20, 2013 | 05:33 AM
cHarley's Avatar
cHarley
11.9v is a dead battery.
There's a difference between "won't start" and won't crank, which is it?
Old May 20, 2013 | 06:12 AM
grbrown's Avatar
grbrown
-Judge
Plenty to worry about! The noise may well have been the starter running while the engine was working, which is not good! Starting on the key and not the switch is also not good! You may simply have a failed starter relay, which is where I suggest you start.
Old May 20, 2013 | 06:22 AM
dtaylor00's Avatar
dtaylor00
I agree. Sounds like your Starter relay is powered on, without being commanded on by the start switch.
Old May 20, 2013 | 07:30 AM
chappy99's Avatar
chappy99
Starter relay,under seat clutch side.
Old May 21, 2013 | 01:30 AM
Judge1989's Avatar
Judge1989
Won't Crank. No starter function at all. The starter has power, Just not doing anything. And that's 11.9v with the headlight on. 12.6~ with it key in off position. I'm gonna tear into it tomorrow morning before work and see what I see. Thanks for the replies guys!
Old May 21, 2013 | 06:56 AM
cHarley's Avatar
cHarley
And that's still a bad battery, if you're measuring at the battery.
Old May 22, 2013 | 12:09 AM
Judge1989's Avatar
Judge1989
The battery may also need replacement. I am not denying that, but may I ask why you say so? .7v~ is an acceptable drop for a headlight if I am not mistaken. If I am please let me know.
parrishbjj
Mar 28, 2014 06:04 AM
Superfly3176
May 18, 2012 04:20 PM
fxsti03
May 9, 2011 08:20 AM
KJeep
Apr 21, 2008 11:25 AM
priceamp
Sep 13, 2006 09:28 PM
