Leaking CV Carb
Old May 27, 2013 | 08:30 PM
92oldskoolxlh's Avatar
92oldskoolxlh
Default Leaking CV Carb
I was looking at my bike today after a long ride and noticed a lot of fluid on my crank case. It was fuel I checked my petcock it was off. My accelerator pump was leaking from the bottom. One screw was loose I tightened it went around the block came back and it was still dripping. I looked up rebuild kits and thought maybe its the diaphragm until I read it goes at the top. Theres no seal its metal against metal and its suppose to stop fuel from leaking out? What do you think the cause is for the leaking? The diaphragm the spring the plunger? Im not sure.
Old May 28, 2013 | 01:22 AM
DOMAPOI's Avatar
DOMAPOI
Your diaphragm is your seal too. So is the little o-ring. If it is actually leaking from your accelerator pump you probably have a cracked diaphragm. Here is the layout of a CV carb for (based on your user name) a 1992 XLH Sportster. But they are all about the same when it comes to CV carbs. Your looking at part #s 42 & 43.
http://partsfinder.onlinemicrofiche....RETOR-ASSEMBLY
Old May 28, 2013 | 01:24 AM
DOMAPOI's Avatar
DOMAPOI
Well apparently the link won't take you anywhere but Ronnie's home page. So, just click on the link near the top that says, "OEM Harley-Davidson Parts Finder" and then click on the blue link under the HD emblem. Choose the year of your bike and then choose the model you have. Then all you have to do is click on the Carb. assembly link it it will list all the parts for your carb.
Old May 28, 2013 | 03:34 AM
92oldskoolxlh
thanks I have both the part book and service manual I just dont see how a diaphram mounted above the spring would stop the fuel from leaking when the fuel goes below the diaphram but thanks. now to overnight the parts and take it apart.I have ohio bike week coming up so hopefully I can get it done in time.
Old May 28, 2013 | 05:51 AM
cHarley's Avatar
cHarley
Just order a rebuild kit and give the carb an overhaul. You can get the kits HERE.
Old May 28, 2013 | 04:22 PM
92oldskoolxlh
charley I plan on doing that but Im going to Ohio next week so it wont be here in time. I bought the diaphragm from hd with the spring and o ring Ill replace them and hopefully it wont leak. When I get back Ill overhaul it.
Old May 28, 2013 | 05:58 PM
John Harper's Avatar
John Harper
That should do it, if everything else is good, get a can of Seafoam and call it a day.
John
Old May 28, 2013 | 07:09 PM
92oldskoolxlh
sea foam wont that put to much pressure into the carb and just break it apart? I wouldnt use sea foam in a car let alone a bike.
Reed's 1200
Mar 23, 2019 01:53 PM
All Aces
EVO
30
Jul 27, 2014 07:42 PM
TheBanditColorado
EVO
Dec 14, 2013 05:36 PM
Nilla
Aug 8, 2012 06:42 AM
ardvark
Shovelhead
May 24, 2008 12:40 PM
