Starting issue
Old Jun 14, 2013 | 06:21 AM
stevekam's Avatar
stevekam
Default Starting issue
09 nightster.
The other day I went to start the bike and the starter turner once and then I heard a click sound and then I lost all power. I turned the key off then back on and power is back and the bike started. It ran a little rough then cleared up. While riding, I put on my left blinker and it was blinking faster than normal, kind of like when in older cars when one blinker light would blow out. Then on the next turn it was fine.
I dropped in a new battery last year so I'll check the connections there. I haven't done any other work on the bike besides change the oil.
What else should I check ?
Old Jun 14, 2013 | 11:25 AM
WVHogRider's Avatar
WVHogRider
Check your speedo to see if any DTC's were set.
Old Jun 14, 2013 | 11:30 AM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Blinker flashing faster than usual typically means there's a short somewhere.
Old Jun 19, 2013 | 07:24 PM
stevekam's Avatar
stevekam
The only thing I found so far was the negative connection on the battery was a little bit loose. tightened that up and it seems good so far.
Old Jun 19, 2013 | 09:40 PM
ghinsey's Avatar
ghinsey
I will bet 2 to 1 the negative cable was you problem. You should be good to go.
06Sportster1200
May 24, 2021 03:55 AM
Matthew Borel
May 19, 2019 07:46 PM
Turbinesaint
Nov 8, 2011 10:17 AM
rollover
Jul 31, 2007 07:02 PM
jnogreen
Jul 22, 2007 05:43 AM
