overheating 883 xl
Old Mar 4, 2007 | 04:34 AM
1200c's Avatar
1200c
Default RE: overheating 883 xl
Actually, I just had an idea. Are you sure the engine is overheating or the bike just shuts down? A common problem with these bikes is the crank position sensor. This could make the bike shut down and hard to restart with some other annoying problems. It could also cause the engine to overheat. If there is a problem with the crank position sensor it should set an error code. See if there are any error codes stored. Do you know how to read them via the speedo?
Old Mar 4, 2007 | 12:30 PM
crash vector's Avatar
crash vector
6th Gear
Yes i'm past buying the extended "fix for free", so I'll have touse thepay asI go method.Yes it does still run hot but not like it did, and it never gets so hot that it shuts down since the rebuild,but I don't get into situations that make me sit for very long with the engine running. Thecrank position sensor sounds like a good thing to check out. I know timing issues can cause heat related problems.I didn't know you could check error codes via the speedo, but I'll check into it right away.
crash vector
Old Mar 4, 2007 | 01:23 PM
dbleagle's Avatar
dbleagle
Just about everything has been covered here so I don't know what I can add...
I am sure you know by now... don't listen when someone says "Oh you got an unlimited warranty"...
When you have a problem such as yours... you need to get a service history started on the bike... your compaint is part of the history and when, as in your case, they can't deny the claim because it is what your brought it in for originally... I was their failure to solve the problem...
Charlie D.
Old Mar 4, 2007 | 05:09 PM
1200c's Avatar
1200c
Here is how to pull out the codes and what the codes mean.
http://www.xlforum.net/vbportal/foru...ad.php?t=18260
jumpinjoe313
General Topics/Tech Tips
May 27, 2016 08:50 AM
starplee
Jun 23, 2014 08:29 PM
BobbyC1965
Jul 13, 2012 10:09 PM
drumer66
Oct 9, 2006 09:26 PM
carsoni
Apr 2, 2006 05:24 AM
