Help with rear lower blocks on Sportster 48!!!
Old Aug 30, 2013 | 08:01 PM
DitosDad's Avatar
DitosDad
Default Help with rear lower blocks on Sportster 48!!!
I just installed rear lower blocks on my 2012 Sportster 48 today. The blocks I got allows you to lower the rear 1" - 3". I put it on the middle hole which would be 2". I checked it out for clearance issues but it looked good while sitting there. I took it out for a test ride and it had some rubbing when I would hit a good dip in the road. After I got back I noticed that the tire had some minor nicks in the center of there tire from the rubbing. Any ideas? Is it from the seat bolt? What if I adjust the shock setting stiffer? Get a shorter bolt for the seat? I love the look of the bike now and I don't want to raise it back up.
DitosDad's Avatar
DitosDad
I will post a pic of it lowered tomorrow!
Old Aug 30, 2013 | 08:39 PM
HDStreetGlide's Avatar
HDStreetGlide
I did 1" on my Iron and gouged the tire pretty good. Stiffened the springs (I weight 170) and it rode like a buckboard. Put on Progressives, not much better so I deep six'd the blocks. Not worth the problems for me anyway.
Old Aug 30, 2013 | 10:08 PM
DitosDad's Avatar
DitosDad
Here is a pic I took just now. Hard to see at night. I will post another pic tomorrow.
Attached Thumbnails Help with rear lower blocks on Sportster 48!!!-image.jpg
Old Aug 30, 2013 | 10:15 PM
grancuda's Avatar
grancuda
Pretty sure you can only run it on the 1st hole from the front. Your shocks are 11" & the holes you have it on are for 12"-13" shocks. If you want it that low, get some 10" rigid struts.
Old Aug 30, 2013 | 10:30 PM
DitosDad's Avatar
DitosDad
That's what I was thinking but wasn't hoping. I wonder if the 10" ridged struts would beat me up too bad? Would you use them?
Old Aug 31, 2013 | 09:14 AM
grancuda's Avatar
grancuda
I am running struts, have about 5000 miles with them now. Mid controls make the struts much better.
Old Aug 31, 2013 | 11:05 AM
DitosDad's Avatar
DitosDad
Here is a day pic. I love the fender hugging the tire look. I might just go with struts.
Old Aug 31, 2013 | 11:07 AM
DitosDad's Avatar
DitosDad
Any pics of your bike with struts?
Old Aug 31, 2013 | 03:11 PM
JB'R's Avatar
JB'R
You can raise the suspension one inch (first hole) and get the same length the struts will give you. If you choose the 10" ones.
I have 13" shocks on my iron and I dropped it two inches, giving me your stock 48's height. The dealer who installed it said if I dropped it another inch I might have trouble with the license plate mount.
What you can do is either remove the passenger seat bolts or modify/get smaller ones and that, I think, will allow you to take it to 9".
