Fuel leak
Old Nov 28, 2013 | 10:23 PM
DOMAPOI's Avatar
DOMAPOI
Have you tried to make sure it is fully snapped into place. I may look fully connected when it isn't. Those same people who have had problems after the take lift kit said it looked like it was fully connected but was leaking and when they tried it actually went up a tiny bit and clicked into place and the leak stopped. Just something to check before you start replacing o-rings that may not need replacing.
Old Nov 29, 2013 | 02:37 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
There is NO known correlation between a tank lift and a leaking fuel Quick Disconnects.
There ARE two known (but relatively rare) causes for leaking fuel QD's
1. Disconnecting the QD for any reason, sometimes it is very difficult to pop it back into place without it leaking...even with a good o-ring AND clean seats. I experience this about one in every 200+ bikes. It can be totally snug against the stop, with a good o-ring and still leak. Solution, disconnect it and reconnect....sometimes it take 5,6, or 7 times til it seats "just right" and doesn't leak.
2. SOME, not all, some 48's & 72's with the 2.1 gallon tank that do a Coil/Key relo (with the ignition above the coil) experience the plastic ignition housing touching the fuel QD. Solution, cut a little portion of the plastic housing, or use a Flex-Six option for the ignition key relo.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
just plain john
General Topics/Tech Tips
16
Dec 10, 2020 10:28 PM
McGuff
Dec 1, 2011 10:53 AM
OCD
Nov 1, 2010 06:58 AM
paulm@cableone.net
Mar 24, 2010 09:17 PM
crock921
Sep 26, 2007 10:49 PM
