Gearing up for 1250 build; any advice?
Old Dec 19, 2013 | 01:10 PM
MicOnti's Avatar
MicOnti
Default Gearing up for 1250 build; any advice?
I'm getting ready to do my conversion and I'm looking for any tips / advice that might save me some headaches.
So heres what I got:
-2010 Iron
-1250 kit (NRHS)
-HD Service manual
-And a well stocked garage..
What I'm looking for:
-Detailed threads on it (I've seen one with pics but can't find any others. I remember there being a old one but can't find it)
-trouble shooting guide
-things to remember / lookout for
Any input would be appreciated,
Thanks!
Old Dec 19, 2013 | 03:31 PM
hank-hill's Avatar
hank-hill
Yes one very important piece of advise
Read NHRS website about torque values for the pistons/heads. I did a Hammer 1250 kit and the gaskets are a different kind than stock and require a different torque spec
Old Dec 19, 2013 | 03:44 PM
baka1969's Avatar
baka1969
https://www.hdforums.com/forum/sport...i-version.html
A few things to think about when working on your bike.
* Be organized- believe me this helps a lot. Get your tools ready to go. Make a check list of the steps you'll be going through. Label all the parts and the parts that come off the bike during disassembly. Take pictures of the specific area you'll be working on before you start. It'll help you visualize when you reassemble. Use a template of the parts you disassemble. A piece of cardboard.
* Be patient- Take your time. Most mistakes are done when trying to hurry or rush. If you get pissed, just walk away for a little bit and return. You're in no hurry. Enjoy the process.
* Research- Between this site, the other Sportster site and YouTube there are plenty places to get your questions answered.
* Tools- Use the right tools for the right job. It's much better to use the proper tool intended than try to improvise. Something as simple as using a T25 torx wrench instead of a T27 can strip a bolt.
* Follow directions- Do what the manufacturer tell you to do with the install and be assured a bike that will give you years of use and 10s of thousands of miles of reliable service
* Have fun
Old Dec 19, 2013 | 05:54 PM
Scuba10jdl's Avatar
Scuba10jdl
You're going to need to upgrade your clutch diaphragm spring. The rubbermount 883's have a light spring and it won't hold up to the 1250 power/torque output.
Old Dec 19, 2013 | 06:50 PM
Madnss's Avatar
Madnss
Go to nrhs website. Instructions on how to assemble. I think they were wrote up by aswracing, one of the most reputable guys in the xl field
Old Dec 19, 2013 | 06:57 PM
baka1969's Avatar
baka1969
Just a note: you'll need a clutch spring compressor tool to change out the clutch spring.
Edit:
http://xlforum.net/vbportal/forums/s...ad.php?t=49915
Old Dec 20, 2013 | 07:56 AM
grbrown's Avatar
grbrown
To find useful threads simply use 'Search' in the blue bar above, go to advanced search, then enter '1250' for threads with that in the title. There are 98 of 'em, so it should be easy to find the one you refer to.
Old Dec 20, 2013 | 10:22 AM
MicOnti's Avatar
MicOnti
just re opened the thread and seen all the great replays. I start today so hopefully I'm posting by tonight. Thanks for the help!!
Old Dec 20, 2013 | 12:05 PM
mrfikser's Avatar
mrfikser
I did it on my 2000 883 ...the only advice I can give is to just do it...its not that tough....oh, and take you time...are you doing cams too???
Old Dec 21, 2013 | 10:16 AM
MicOnti's Avatar
MicOnti
No cams yet.. figured I'd start with this and see where were at with the ponies.
Update:
Finished the fun stuff last night. First cylinder was slow and tidious but second was much better. I had some problems with two Allen bolts and the snap rings but other then that it went pretty smooth.. I dress her back up today then the heat treat.
