Air mixture screw
Old Jan 15, 2014 | 07:43 AM
willsport's Avatar
willsport
Stage III
Default Air mixture screw
Hello there. I am new to this forum. I have a '06 Sporty 883. Recently I installed a Dynojet carb kit. My question is this, the instruction want you to turn the Air mixture screw out 3 1/2 turn. So is that 3 1/2 complete turns or just every 1/2 turn 3 times? Thanks for your time.
Old Jan 15, 2014 | 07:49 AM
Scuba10jdl's Avatar
Scuba10jdl
Follow the instructions at the following site: http://www.harley-performance.com/ha...arburetor.html
It's likely that 3 1/2 turns out is not the best setting.
Old Jan 15, 2014 | 08:31 AM
John Harper's Avatar
John Harper
I've had a dynojet kit on my '91 for over 20 years, pretty sure my air mixture screw is somewhere between 3 and 3.5 turns out. Plugs read good, bike runs great.
John
Old Jan 18, 2014 | 07:56 AM
willsport's Avatar
willsport
Stage III
thank you for your help. I do have a dynojet kit on it.
Old Jan 18, 2014 | 06:23 PM
Triumph Jerry's Avatar
Triumph Jerry
Just some info for you and others, ...counter clockwise makes it leaner, clockwise makes it richer.
Backing it off gives it more air, hence the term "air" screw.
Most folks think unscrewing it (counter clockwise) gives it more gas, less air.
Counter clockwise = white spark plug base (too lean)
Clockwise = black/sooty spark plug base (too rich)
You want a tan/grey spark plug base, with a clean petty coat (bottom ceramic)
Old Jan 18, 2014 | 07:42 PM
Scuba10jdl's Avatar
Scuba10jdl
No! This is completely wrong. Wrong, wrong, wrong. It is not an "air screw" like on some Jap bikes. It is an idle mixture screw.
Essentially, it is a needle valve with the orifice flow controlled by the tip of the screw. It controls the amount of fuel allowed into the throttle plate bypass orifice to mix with that air.
Turning it in, or clockwise for a standard thread, will lean the mixture out. Less fuel is allowed through.
Turning it out, or counter-clockwise for a standard thread, will richen the mixture. More fuel is allowed through.
t150vej
EVO
Apr 22, 2009 06:57 PM
Big Hog
EVO
Mar 28, 2009 01:22 PM
Ca.Fatlad
Dec 8, 2008 05:36 PM
SportyPig
Aug 21, 2006 06:46 PM
Seabass
Oct 4, 2005 10:31 AM
