I have a Non-California PCV on my 2009 883. Based on what I read, I understood it that the rev xtender could only be activated with a code received from DynoJet. So I sent away for the code and this is the response I got along with the code:
"The following key-code can be used to return the Rev X-tend feature in your PC5 back to the default level of 6400 RPM."
Back to? I thought it was at the factory 5500ish. If not, does anybody know what they come set at from DynoJet? Based on the "back to" I assume it was set higher. If so, why do they require a code to lower it?
