Clicking noise when starting
Old Mar 24, 2014 | 07:17 PM
typennies79's Avatar
typennies79
6th Gear
[QUOTE=cHarley;12482647]Yes
No, just like test 1. Neg lead to ground, Pos lead to small wire terminal.[/QUO
first test read 11.56
Second test read 11.42
Old Mar 25, 2014 | 07:55 AM
typennies79
6th Gear
It was pretty much the same voltage as the battery at the time of ignition. Is that normal?
Old Mar 25, 2014 | 10:59 AM
cHarley's Avatar
cHarley
Those voltages at the starter look normal. At this point I would pull the starter out and test it on the bench.
Old Mar 25, 2014 | 11:03 AM
typennies79
6th Gear
It reads the same with both my old starter and a brand new one. Very odd
Old Mar 25, 2014 | 12:19 PM
cHarley's Avatar
cHarley
Have you already replaced the whole starter?
Have you tried hooking up the old starter on the workbench to check its function?
Old Mar 27, 2014 | 08:23 AM
typennies79
6th Gear
I did replace the starter.im going to try and test the old one on the bench on saturday. Also going to check the ground wires on the bike
big-bad-wolf
Jul 11, 2014 05:24 AM
sportyfrahm76
May 31, 2012 01:10 AM
cadore
Mar 11, 2010 07:32 PM
JonnyDeluxe
Jul 13, 2009 04:49 PM
MITYBAGGER06
May 27, 2008 01:30 PM
