Will they fit?
Old Apr 29, 2014 | 06:44 PM
dustydog2's Avatar
dustydog2
Default Will they fit?
I have a 97 xl1200c.....16" rear, 21" front....found some black wheels w/chrome spokes off of a 2014 Streetbob.....17" rear w/160/70b17 tire, and
a 19" front w/100/90b19 tire....will they work, or will there be too much mucking around?
Who is the Wheel and tire Guru?
Old Apr 29, 2014 | 07:05 PM
Raulgutz's Avatar
Raulgutz
Wheel bearings might be an issue.
Old Apr 29, 2014 | 07:09 PM
dustydog2's Avatar
dustydog2
like a sleeve to compensate for different size axels?
Old Apr 29, 2014 | 08:55 PM
Raulgutz's Avatar
Raulgutz
I believe the old axles where 3/4 front and 1" back. And your new wheels might have 25mm bearings and sleeves front and back.
Old Apr 30, 2014 | 04:08 AM
grbrown's Avatar
grbrown
I suspect you will find there is a lot of mucking about! The rear rim is much wider than yours and I suspect the tyre will be wider than your fender - a 150 will go in, but a 160 may not. Hub dimensions may also be wider. Your wheel bearings are 3/4" tapered rollers, the SB has 25mm sealed *****. You can probably swap those for 3/4" sealed *****, which will avoid the need for sleeves, but axle spacers may need adjustment. It can probably be done, but not as a simple bolt-in.
Old May 2, 2014 | 02:41 PM
dustydog2's Avatar
dustydog2
grbrown...thank you
BigDevil
Jun 16, 2013 08:29 PM
johnny knuckles
Aug 11, 2009 04:22 PM
incrediblah
Mar 27, 2008 04:10 PM
incrediblah
Mar 27, 2008 10:19 AM
hogdad
Feb 28, 2008 08:32 PM
