Turn signal relocation
Old Aug 3, 2014 | 03:11 PM
davisr014's Avatar
davisr014
Default Turn signal relocation
I recently go this J&P Cycles® Chrome Rear Turn Signal Relocation Kit for my 2014 Superlow. It did not come with any instruction for it. I've done searching and have not found any instructions. Is there any out there?
Thanks
Old Aug 3, 2014 | 04:39 PM
HarleyScuba's Avatar
HarleyScuba
We can probably help, but we'll need to know which rear TS relocation kit you're talking about. A part # would help.
Old Aug 3, 2014 | 10:03 PM
davisr014's Avatar
davisr014
Sorry about that i was aiming to include it this morning. The part number is 306-934.
thanks
Old Aug 4, 2014 | 03:20 PM
HarleyScuba
Here's the same deal from Harley. These are their instructions:
http://www.harley-davidson.com/app-c...ts/-J03892.PDF
I went to Harley's site, found the part and looked under "More Info". That's where they put install instructions.
You don't need to cut the wires. The metal terminals at the ends of the wires can be removed from the plastic plug and re-inserted after the wires are run through the turnsignal mounting stalks. The trick is getting the terminals separated. There's a tiny mechanism in there that releases the terminals, one at a time, from the plug. I'm not certain which style terminal is used for the T/S plugs, so I won't go into further detail, clouding the issue. Check this resource, find the plug you're dealing with and go from there. I think Figure B-2 and B-3 are the ones you want:
http://mael.rivoal.free.fr/Manuel%20...R/sm_appb1.pdf
If you do cut the wires, and plan to re-use the existing plug, make your cuts staggered. This prevents a giant bulge in your repair. Solder and shrink tube work pretty good, but I prefer removing the pins (terminals) from the plug. You probably know all this little stuff, but don't hesitate to ask.
Old Aug 5, 2014 | 09:50 AM
davisr014's Avatar
davisr014
awesome, thank you
itsmyforte
Sep 8, 2018 03:08 PM
folkxrock
Aug 31, 2009 08:53 AM
June Bug
Mar 8, 2009 03:06 PM
fishawk
Jan 13, 2007 12:23 AM
baxter
Aug 14, 2006 12:30 PM
