The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: TT AT vs PV Basic AT
Old Jun 30, 2016 | 02:51 AM
  #131
mirrmu's Avatar
mirrmu
look forward to the testing
Old Jun 30, 2016 | 06:53 AM
  #132
whittlebeast's Avatar
whittlebeast
Originally Posted by oleboy
Andy,
Sorry, I don't really understand your response. Can you expand on your response?
If my map (open loop portion) was auto tuned with the AT basic and then I set the AFR table back to 12.8/13.0. Will this not work?
I answered your question the best I know how over on the other thread.
https://www.hdforums.com/forum/the-d...l#post15283567
Andy
Old Jun 30, 2016 | 07:29 AM
  #133
Wide Open Cycles's Avatar
Wide Open Cycles
Former Sponsor
Let's keep this civil, there's some good info in here and i'd hate to see this get locked. It's not worth anybody getting "banned" over.
I FedEx'd a wide band kit to oleboy. We spoke and he seams very eager to do this test, after speaking with him I am confident he will give us a good test and I am as eager as anybody for the results. I have run similar tests myself but in an effort to not "appear" biased I, for the most part, keep the results to myself. I'm very curious to see if oleboy comes to the same conclusions as I do.
Old Jun 30, 2016 | 07:50 AM
  #134
hrdtail78's Avatar
hrdtail78
Originally Posted by whittlebeast
This can be done reasonably well with narrow bands provided the PIDs are set the way they are in the big twins
Andy
What level of calibration is your sportster running on?
You want to know some facts Andy? They didn't change anything for the sportster. It is the same as the other big twins as far as the closed loop for that level of calibration.
Old Jun 30, 2016 | 07:58 AM
  #135
hrdtail78's Avatar
hrdtail78
My 140 HP Yamaha FZ1 runs a DJ PC5 on closed loop widebands and 60 HZ data logging.
Andy
When did the PC5 become capable of running closed loop?
Old Jun 30, 2016 | 08:21 AM
  #136
Mr. Wizard's Avatar
Mr. Wizard
I removed the obvious.
Stating again... good debate is fine but when it gets under your skin back away and post later.
Old Jun 30, 2016 | 08:40 AM
  #137
whittlebeast
see http://www.powercommander.com/powerc..._autotune.aspx
Old Jun 30, 2016 | 10:40 AM
  #138
hrdtail78's Avatar
hrdtail78
I see that DJ marketing and verbiage got another. This isn't a closed loop system or even an auto tune. You collect data and down load the trims out of the PCM in one area of the map and then you must apply them to another area of the map and download that map in order for them to take affect. It doesn't automatically do this for you or does it control anything with a closed loop feed back.
Editing to say that this is wrong. The PC5 does make adjustments to the PC5 calibration with out accepting and applying them to the PC5 calibration. I was not aware that it did do this. I apologize for giving out wrong information, and hope this hasn't lead anybody astray.
Old Jun 30, 2016 | 11:22 AM
  #139
hrdtail78's Avatar
hrdtail78
I'll answer my own question. Here is the cal description from HD. As we can see the sportster uses a 176 level calibration. This same level is used on several different models including 07-11 dyna's, 07-10 softails, 07 touring and some Vrods. It isn't something they did special for sportsters.
File Type: pdf
Old Jun 30, 2016 | 12:13 PM
  #140
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Your description of how PC-V/Auto Tune operates & how the trims are applied is absolutely incorrect. PC-V Auto Tune is a closed loop system, Power Commander is a piggyback controller and does use not closed loop logic native to the Delphi ECM it uses the PC-V module/processor and closed loop with its own wideband O2 controller. The PC-V map has an AFR table which controls the commanded AF; Auto Tune maintains this mixure with live correction. You have about 250 break points/cells (per cylinder) for your targets and this configuration can be found in the PC software tree view menu on the left under Primary Module>Auto Tune>Target AFR. As you ride the Auto Tune populates trims and it makes corrections in real time, these trim can be be monitored in your device under Primary Module>Auto Tune>Trims, they can also be applied back to your base map by selecting Map Tools>Auto Tune Tables>Apply Fuel Trims. Auto Tune (closed loop) is configurable by min run time, engine temp, and you can set the min/max enrichement/enleanment %, PC-V also has an input for a switch that allows you to turn Auto Tune on/off or it can be configured to switch between multiple maps both of which can be done on the fly. Hope this info helps
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
