No Device: scatter graphs and statistics
http://www.nbs-stl.com/MLVDemo/012%2...ngEquation.PNG
Harleys add in a couple of unique ones that are not included here but this is still the heart of all EFI tuning. It is all just math.
Andy
Can you show anything that validates that this is something that is actually used and not just something you came up with. Any proof that any Delphi system uses this or that a HD Delphi system uses it?
Until then. This shouldn't be put out like fact but Andy's theory.
Base pulse width is how long the injector is energized.
Seems like a remedial question for somebody that has based their whole tuning strategy on pretty graphs based on how long the injector is staying open and MAP x RPM.
What about post 113?
Andy
I understand that Andy, and if you really want to know. You have to use flow meters. Just like everybody else has found out. You are never going to be able to pin down the actual dead time of an injector. Let alone both of the injectors.
Harley tries to do this with miles to empty. Might be close on a cross county holding cruising speeds but they are all jacked up when pull them from the dyno.
I disagree. Most people know how to turn on and off a hose.
You tell me. Nobody else is getting involved.
If we knew the dead time of the injector and if it was reported or not. It would be easy to set a global filter on this channel, but this would just shift indicated data from the channel. To get anywhere. We would need to model the injector for thermo resistance vs volt/pressure vs manifold pressure. Then we would be getting there. ....and it would still be only a model.
http://www.nbs-stl.com/HarleyTuning/...d%20Sporty.png
Now two Target Tune equipped bikes.
http://www.nbs-stl.com/HarleyTuning/...Sporty%202.png
And a Dyno tuned TTS bike with the wideband option being used.
Andy
Andy
(note I've added +10 to the rear cylinder is why it is higher on the chart, otherwise the two would be pretty muck on top of each other within a couple of % duty cycle)
