No Device: scatter graphs and statistics
http://www.nbs-stl.com/HarleyTuning/...d%20Sporty.png
Now two Target Tune equipped bikes.
http://www.nbs-stl.com/HarleyTuning/...Sporty%202.png
And a Dyno tuned TTS bike with the wideband option being used.
Andy
Notice how the graph he post for the narrow band and mostly autotunes. The hit dots are huge, but then the TT equipped bikes the hit marks are tiny. This a carney trick some play with scaling to show you an apples to oranges comparison being played off as a apples to apples.
Shame on you Andy. Continuing to post BS and BS data should be ground to get you kicked out of here.
I would be concerned ate the top right corner of that plot. It is likely something is wrong in the tune.
Wow you are good at Excel. You would go over the top if you had software designed for doing this sort of thing from day one.
Andy
On a half decent Lambda/AFR table you would expect it to go from leaner at idle cruise, out to richer at higher loads i.e. out towards right/top of that graph, no?
On that kick, the Rear is noticeable but the Front not so, to my eye ...or do you think there is a bit something up on both? I'm wondering just how straight do you think those lines should be?
see http://www.nbs-stl.com/HarleyTuning/...20to%20MLV.png
Andy
I did post raw data. Haven't seen you post anything besides the same screen shots you have been posting for years.
Keep talking Andy. You are helping me with why I started this thread. You have done nothing but play games, topic hop, avoid questions and show your ignorance of how a HD ECM works. You haven't backed up a single statement. You have proved just pics of scatter plots are not enough and how they really don't do anything. Even you want the raw data.
"You would go over the top if you had software designed for doing this sort of thing from day one."
What, like TT software, because you couldn't tune your sportster with MLV until you installed TT?
I have software designed for doing this, but don't worry. I do have MLV also.
BUT none of this has shown how scatter plots can be used for tuning.
Like Gordon points out. AFR isn't linear. On WOT pull from 1750 to 6500 the AFR can be a bit richer at the bottom to address hard roll on detonation, and then lean out in the middle of this and then richen back up when PE mode kicks in. When does PE mode kick in? All depends on how it is set up and how long the bike is at 100kpa or 100tps depending on what level of calibration it is.
HP is not a function of duty cycle. Duty cycle of an injector is nothing more than how long the injector is open compared to the allowable time it has to be open displayed in a percentage.
Lets look at an look at 6000 RPM's for an example. At 6000RPM's you have 20ms to spray fuel between intake valve close to next intake valve close event. If the injector is energized for 16ms. That would be considered to be a injector duty cycle of 80%. Because the injector is staying open 80% of the time it could be open and get fuel for that engine event. Let's look at 5000RPM's. In order to have a 80% duty cycle at 5000 with a the allowable time to spray of 24ms. The injector needs to be energized for 19.2ms. It doesn't tell you anything more than that. How much fuel is that? Who knows. More info is needed. Like what size of injector is it.
So, Andy is now blaming DC for the reason the sportster I posted isn't carrying its power to redline. After he has tried to blame other things and have been shot down. The straw he is grasping for is IDC. Here is the problem with that. How much fuel being delivered doesn't determine the amount of power. If this was so. Why wouldn't we just run all WOT at 10:1 or richer? Just keep adding fuel until we are on the verge of washing cylinders? Because it takes fuel and air to make power. Engines/ fuel types like a specific ratio of both to make power. So, if you look at data and see that there is no more air getting into the engine from 5200 on up. Chances are the power is going to flattened out. If we see that the engine isn't taking more fuel over 5200 but the ratio stays at our desired ratio. Chances are the power is going to flatten out. Doesn't take a wiz bang program to see this. What can be the cause of lack of air? Head, cams, intake, exhaust. Or look at it this way. How can we get more air through the engine up at these RPM's? Why does headwork and larger TB's produce this power up top? Because this lets more air to be pumped through the engine. Which allows the addition of more fuel and with both. That equates to more power.
This is all some pretty basic stuff guys, and as we see. Andy doesn't have a clue.
Let's take a simple motor running 2500 rpm. That works out to 48 ms to rotate the crank shaft 720 degrees or one full engine cycle.
Lets assume the code is reporting a Pulse Width of 8.86 ms
8.86 ms / 48 ms = .1846 or 18.46% Duty Cycle.
But the dead time of a fuel injector is about 1 ms, so the actual spray time is
(8.86 ms - 1 ms) / 48 ms = .1637 or 16.37% Duty Cycle effective fueling time. Let's say we find that the AFR as read by the wideband.
Now let's see what happens if we change the PW to 7.98 ms.
(7.98 ms - 1 ms) / 48 ms = .1454 or 14.54% Duty Cycle
16.37 Effective DC / 14.54 Effective DC = 1.126 or a 12.5% change in fueling.
8% to 10% is normally about one AFR so 12% is close to 1.5 AFR or the 14 AFR we had at 8.86 pulse width will end up about 15.5 AFR
If you take 14 AFR * 1.126 = 15.8 as the new AFR in theory. That is real close to our 15.5 AFR Rule of Thumb guess.
So a swing of Pulse Width of 8.86 to 7.98 will swing the AFR right at 1.5 AFRs if there is no other changes in RPM or throttle position or MAP.
Everyone follow me so far?
Andy
