The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
I just purchased an advertised 61019 but it turns out it is probably a 61009. I tried to get a map from V&H but all they wanted me to do was to buy a new FP3. I want to use this 61009 on a 2011 FLHTK but V&H said it won't work. It will work on a 2010 FLHTK. What changed other than V&H going from a LED version to a LCD version? What map should be used it I can even use it? Any help would be greatly appreciated!!!
I just purchased an advertised 61019 but it turns out it is probably a 61009. I tried to get a map from V&H but all they wqanted me to do was to buy a new FP3. I want to use this 61009 on a 2011 FLHTK but V&H said it won't work. It will work on a 2010 FLHTK. What changed other than V&H going from a LED version to a LCD version? What map should be used it I can even use it? Any help would be greatly appreciated!!!
IMO, when a mfg says their product doesn't work with a particular application, they MORE THAN LIKELY have discovered the issue from their testing and/or customer feedback.
That said maybe purchasing a serious tuning device and software will met a better running bike than anything else.
If that's not important there is a plethora of highly marketed self, auto, wiszbang products claimed to produce a great running bike by using their screwdriver, push buttons, and/or smartphone, tuning systems.
IMO, spend the money to do it right and you will never regret it.
Bob
