The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
No Device: How does PE Mode work
Old Aug 23, 2016 | 05:24 PM
Fishonsc's Avatar
Fishonsc
Originally Posted by hrdtail78
Something to keep in mind about PE mode, and what it can do for us. I picked CAA009 from TTS file for example. I just picked one.
W/ PE mode not activated:
Riding your fully loaded bagger w/ rider on back. You're cruising 85mph down the highway. You open WOT to climb a hill. At first you will go up to 100kpa and you will be in the target area of 856/ 12.7:1. But as RPM's go up. KPA is going to drop. If it drops back to 85kpa @ 4500rpm. Now you are going to be in the target area of 899/13.2. Target AFR is by KPA and not throttle position.
W/ PE mode activated:
Same scenario but now with PE mode activated it is going to stay at the target in the PE table. So, KPA drops. It isn't going to lean out.
Power Enrichment as it is labeled.
I understand what you are saying. In the tune I am running now sets pe mode to come on at 95% TP. In the scenario you describe I would not even get close to 95% TP. Should I lower that #? Just trying to learn. Thanks!
Ericjameshvac@gmail.com
Jun 19, 2017 09:01 PM
Big Dave
The Dyno Room
Jun 13, 2017 07:13 PM
uwiik
Oct 21, 2013 01:18 PM
phat96
EVO
Feb 16, 2009 09:36 AM
broke joker
Apr 11, 2006 01:41 PM
