The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Milwaukee 8 Testing
Old Sep 1, 2016 | 07:14 AM
  #61
Heatwave's Avatar
Heatwave
Member
Originally Posted by Gordon61
Their upgrade cams are EPA as well did someone not say?
I assumed they were epa but I was surprised they were identical in both the 107 and the 114. I believe they used different stock cams in the 110 vs the 103 last year.
Old Sep 1, 2016 | 07:19 AM
  #62
Heatwave's Avatar
Heatwave
Member
Originally Posted by rigidthumper
HD has three cams to offer, all EPA compliant when installed as part of a kit and used with the street tuner. Aftermarket guys have two new designs ready for testing, possible a whole lot more. Looks like the tuner's almost ready. Will be exciting to see what transpires
There are 2 "POWER" cams and 1 "TORQUE" cam. All 3 are epa compliant which means they are probably dead above 4500 rpms. Here's a pic of the M8 optional cams from the "New Products" catalog I got from a dealer.
M8 Optional Cam Specs from new products catalog.
Old Sep 1, 2016 | 09:09 AM
  #63
Max Headflow's Avatar
Max Headflow
Originally Posted by Steve Cole
At this point in time, there will not be a simple switch in the TTS product. They will be setup to work as people are familiar with today. I have been working with Torque base ECM's for a long time and it takes a real good understanding of how making one small change effects many different things in the code. One simple change in a torque request can and does effect mixture, spark and other things all at one time. The ability to build a torque model of the engine itself would have to be done for each and every engine combination for starter. With out the necessary tools and written instructions on how to work with it all, people will be lost. To get a product done and to market has to come first. Afterwards, I may sit down and start working on something more but there is just not the time right now for it all. Just look around and tell me who out there is even putting out instructions and manuals now of how things work and I think most of you will understand why I've made this decision.
I've been thinking about torque management versus tps based throttling.. Since the ECU system design is still speed/density the VE tables still have to exist.. VE is still what the ECU needs for fueling.. That part doesn't change.. What does change is lookup between throttle input and throttle blade position. With the advent of electronic control of the throttle position, there was a simple one dimensional table added between the DC rheostat in for throttle request and throttle blade position. With the coming of TQ control, that DC value now requires lookup into a 2 dimensional tables that also has RPM selecting throttle position..
So essentially, you'll always have to set VEs to tune the system but there is an added table that will eventually need to be set if the TQ curve on the vehicle changes drastically..
It sounds like the current methodology is to disable torque management for tuning then re-enable once done and not mess with the Torque / RPM / Throttle Position table.. I guess later a way of updating the torque management table from torque output would eventually be needed.. The ideal way to do this would be with a brake type dynamometer instead of a inertial dyno. I do think the inertial dyno can be made to work to some extent tho.
Whats the long term plan?
Old Sep 1, 2016 | 09:15 AM
  #64
Max Headflow
Originally Posted by Heatwave
The 3 cams are available in the '17 Screamin Eagle parts catalog. I believe there are 2 "Torque" cams and 1"Power" cam. All 3 are epa compliant which means they are dead above 4500 rpms.
I would assume that the Torque cam favors tuning over a narrow RPM range on the low side of the RPM scale while the power cam favors more TQ in the upper RPM range to make more HP. Why would the HP cam be dead above 4500?
If it is wouldn't the HP and Torque cam be essentially the same?
Old Sep 1, 2016 | 09:23 AM
  #65
Heatwave's Avatar
Heatwave
Member
I'm guessing to meet overall emission standards. No significant difference from the stock cam in my limited opinion. I'm guessing these cams just move the powerband by 500 rpms to different locations on the overall power curve but still maintain the same overall fuel consumption and burn rate as the stock cam to meet emission standards.
That's why I believe the aftermarket cam designers will be working on cams designed to burn more fuel, suck more air and produce more power than the constraints that the MoCo had to operate within for the EPA and the States (in particular California).
Old Sep 1, 2016 | 09:35 AM
  #66
Gordon61's Avatar
Gordon61
The current TBW has more control than a single lookup table does it not? but I wondered if the new was just a variation on what there is already - VE/AFR and TBW throttle control with an idea of torque management (as in you aint getting full throttle if you are lugging it)
But I think a proper torque calibration map ties throttle position and a number of external inputs into controlling both air, fuel, and target AFR at the same time. But the airflow efficiency or VE is still needed in the calculations, hrdtail described it as VVE
If there are VE tables in there then tuning them the old way keeps things going but if the engine is configured to run a torque demand calibration, surely chucking a new cam in is going to throw that calibration out the window and degrade the smoothness of throttle to torque delivery??
There are some interesting papers out there on ECU torque calibrations but I suppose it depends on how HD have implemented the beast
Old Sep 1, 2016 | 10:36 AM
  #67
Max Headflow
You are right about current throttle blade control being 2 dimensional.. I seem to remember the control being a single dimension table but the one I just opened shows 2.. with upper RPM setting being only 2500..
The same map shows TP% as input.. So the top of the table changes to Torque request?
Old Sep 1, 2016 | 10:37 AM
  #68
rigidthumper's Avatar
rigidthumper
In a word, yes. As I understand it, torque managed tuning uses a "torque available" table based on the output of the engine. If you modify the engine to now produce 25% greater torque, the TA table will be off 25%, throwing all the math inside the ECM off. Currently we have VE/spark tables that allow us to correct calibrations. Maybe we'll be able to correct TA tables?
Gonna take some time to process this...
Old Sep 1, 2016 | 06:22 PM
  #69
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Lots of rumors of what is in the engines for parts. I've been told many things already some of which are true and some are not. Even what is in the Harley parts book isn't correct, once you call in to them. So I will hold from answering things until I know for sure. What I can tell you is we are tuning away and solving any issues we find. We are not yet making finial tunes but I can tell you we have several combinations of parts here to test with and several at our testers site. Below are just some of the parts that are in our possession now and ready to be tested.
HD Stage I
HD stage II Torque
HD Stage II Power
HD Stage III Power
TTS Test Cam 1
TTS Test cam 2
Aftermarket prototype slip-ons
At some point we believe the injectors are going to be too small so we are looking for larger replacements at this time too. The dyno charts we will be posting will NOT be finished tune but yet where we felt it was "good enough" to prove what were looking for. In the end we will be taking each combination from the two 107 bikes and comparing what one wants versus the other to try and find any difference we may need to handle in the tuning software. Then the finial tune calibration will be developed. The 114 will get parts after the 107's are done.
Old Sep 1, 2016 | 06:35 PM
  #70
Heatwave's Avatar
Heatwave
Member
HD Stage I
HD stage II Torque
HD Stage II Power
HD Stage III Power
TTS Test Cam 1
TTS Test cam 2
My understanding (although I have yet to see a part #) is that there are larger injectors for the M8s. I believe they are 6.2 gms/sec according to the one P&A Mgr at a dealership in Mass that I spoke with.
