The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: TTS widebands
Old Apr 27, 2023 | 08:25 PM
2deuceguy's Avatar
2deuceguy
Default TTS widebands
Can anyone tell me how to set up a green TTS to record with widebands? I'm tuning the bike with PV, but am wanting to log with TTS and a DTT WEGO III system. I got everything hooked up (I think), and am recording a run, I save that then try to enter the log into MyTune in log type TTS wide and it won't accept it. I enter the same file under TTS Narrow (in MyTune) and it goes in. What am I doing wrong here? Trying to tune a 2021 RGS, which my other logging equipment won't work with. Thanks for any help guys
Old Apr 28, 2023 | 07:14 AM
WKNDS's Avatar
WKNDS
I use Mastertune and am not familiar with 'MyTune'.
What 'app' or 'program' is that ?
Looking at the TTS Mastertune website, for the Green interface, it
shows that Datamaster BT should be used to view logs....
If used with wideband O2 sensors, VTune BT can calculate open-loop fuel corrections...
T.
Old Apr 28, 2023 | 07:48 AM
rigidthumper's Avatar
rigidthumper
Mytune requires a $199/year subscription to use wideband data.
TTS green dongle can use a variety of wideband sensor data with V Tune, but you have to have a TTS MT9 file in the ECM, not a PVT. You can still use it to record data, but have to manually edit the PV map.
Old Apr 28, 2023 | 08:09 AM
2deuceguy's Avatar
2deuceguy
Yes, I'm tuning this on my dyno. I have the 199 subscription. I was trying to record wideband data through TTS just for logging purposes, then enter those logs into MyTune to make the PV VE tables. 1st time trying this and wasn't sure if it would work or no. It did tell me I had to have the MT9 file to record Vtune data. PV works to log, but it's so slow it's ridiculous. Trying to find some other way to log with the 21+ bikes. I usually use twin scan and WEGO for that, but no way to use that on the 21+, at least not to my knowledge anyway.
Old Apr 28, 2023 | 08:10 AM
2deuceguy's Avatar
2deuceguy
T.
MyTune is a program to enter log files and produce VE tables, long story short.
Old Apr 28, 2023 | 11:25 AM
rigidthumper
On the 21 and newer bikes, I find it easier to use my green VCI for data collection/V Tune, and the red BT VCI for flashing.
Old Apr 28, 2023 | 11:41 AM
2deuceguy's Avatar
2deuceguy
TTS is my tuner of choice, but I use PV more than anything. Being able to use a license makes things way easier and most in my area are running PV. I'm hoping DTT (or anyone for that matter) comes out with something for the 21+ soon.
Old Apr 28, 2023 | 06:37 PM
rigidthumper
Or, God forbid, maybe DJ gets C3 functioning like it's supposed to...
Old Apr 28, 2023 | 06:52 PM
2deuceguy's Avatar
2deuceguy
Lol it could happen! Yeah......
Old Apr 29, 2023 | 07:13 AM
hrdtail78's Avatar
hrdtail78
Are you exporting the data out of Datamaster into a file? Then putting that into MyTune? BUT it still doesn't work. MyTune needs desired AFR. MasterTune only read Lambda Desired. MyTune will let you know wants you try and inport and exported data DM file.
