"The Florida Crew" Rides and Information From The Florida Crew.
Headlight bulb options
Old Apr 30, 2012 | 11:39 PM
Chris111's Avatar
Chris111
Default Headlight bulb options
I could use some more light on my sportster as there are times when it's difficult to see at night. I'm not really sure which bulb to buy so I figured I'd get some opinions here.
Old May 1, 2012 | 08:43 AM
cHarley's Avatar
cHarley
If you're talking just a bulb replacement, get a PIAA Extreme White bulb.
They make LED headlights that are super bright, but the 5.25" Sportster size version doesn't work as well as the 7" used on the BTs. Not worth the $400.00 IMO.
Adding aux driving lamps is an option, but that depends on what year Sporty you have. 06 and earlier only have a 22amp charging system, so you have to pay careful attention to your total power load.
Old May 1, 2012 | 10:35 AM
Chris111's Avatar
Chris111
The bike is a 94. I'd rather jist replace the bulb with the brightest I can go without melting wires or causing other problems.
Old May 1, 2012 | 10:41 AM
Just Dave's Avatar
Just Dave
As Charlie said The Piaa Extreme white is a great bulb and will make a huge difference but are a bit pricey, 50 buck range but the will last for a long time.
Sylvania silverstars are a huge improvement over factory but will not last long with all the punishment it is gonna get in your bike being on struts. They are about 12 bucks.
Don't get a high wattage bulb because they will melt your plug. Don't ask me how I know that.
Old May 1, 2012 | 11:07 AM
cHarley's Avatar
cHarley
Yep, they're pricey, but the best way to buy them $$ wise is on-line and by the pair.
http://www.bikerhiway.com/piaa-h4-xt...ack-p-259.html
Old May 1, 2012 | 11:18 AM
Chris111's Avatar
Chris111
Sweet lord...that's pricey for bulbs. I'd rather get an hid kit if I were going to spend money. I don't want to do that though for many reasons.
What wattage can I use without problems?
Old May 1, 2012 | 11:48 AM
Just Dave's Avatar
Just Dave
60/55 watt is as hot as you want to get with factory plugs. Here are the PIAA's a little cheaper online. http://www.google.com/products/catal...d=0CKIBEPMCMAQ
Old May 1, 2012 | 02:59 PM
mrjimbo's Avatar
mrjimbo
How much is being able to SEE worth?......IJS
Old May 1, 2012 | 05:25 PM
Chris111's Avatar
Chris111
I went ahead and grabbed a silver star until I figure out what I want to do. For the money I may as well just do an hid kit and be able to see plenty. That might be a little fancy for me ha!
Old May 1, 2012 | 06:30 PM
cHarley's Avatar
cHarley
Good luck finding a place on the Sporty to stash the HID ballast assembly.
