The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Need some advice
Old Jun 1, 2012 | 10:30 PM
Lucky Charmz's Avatar
Lucky Charmz
Default Need some advice
Hello everyone
I just bought a 2001 sportster 1200 xl custom and its not idling right. When I have the choke out its fine idles perfectly but with the choke in it stalls out unless I give it just a tiny little bit of throttle. Its got a aftermarket air breather and im wondering if the bikes not getting enough air. If anyone can help id appreciate it
Old Jun 1, 2012 | 10:56 PM
myglide's Avatar
myglide
Have you tried turning the idle up? Is it carburated or fuel injected? Does it run fine other than just at idle?
Old Jun 1, 2012 | 11:54 PM
blackbear's Avatar
blackbear
sounds like you need a carb rebuild.You probly have some junk stuck in the jets.
Old Jun 2, 2012 | 12:13 AM
Lucky Charmz
Thanks for the tips.
Its got a carburetor. I guess ill have to get a manual so I know what im doing. Not really sure how I would go about it Im not that mechanical inclined to rebuild a carb.
Old Jun 2, 2012 | 12:22 AM
Lucky Charmz
Myglide
Yeah it runs great. Except when idling. im going to do a oil change and change the plugs because I dont know when the last time anything was done to it. I picked it up off my landlord. he got it from a guy who owed him money ive got to get a speedometer for it so I can get it inspectedbecause I guess the original owner thought it was cooler not to have one.
Old Jun 2, 2012 | 12:37 AM
myglide's Avatar
myglide
If you can hold a steady speed low rpms or high with out it hesitating or missing and accelerate and decelerate without problems I would turn the idle screw in some to make it idle higher to see if that helps. Put some Seafoam in the fuel to help clean things out. If it still does it I would think to check the idle/slow jets etc. for dirt/plug.
Old Jun 2, 2012 | 01:00 AM
Lucky Charmz
Sounds like a plan thanks
Old Jun 2, 2012 | 01:10 AM
Stiggy's Avatar
Stiggy
If the bike has free flowing pipes and a free flowing air cleaner, the carb should have been re-jetted. The fact that it idles better with the choke pulled indicates that you're running too lean. ( Even stock bikes are set a bit too lean from the factory.)
It's about a 1/2 hour job to re-jet it.
blue-42
Mar 30, 2018 03:50 PM
86glider
EVO
11
Oct 11, 2017 03:40 PM
HighwayStar
Jan 5, 2017 08:31 PM
843chris
Jul 20, 2013 01:46 PM
HDJeremy
Exhaust System Topics
Apr 3, 2009 04:35 PM
