O2 Sensor question
Old Sep 23, 2014 | 12:40 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Originally Posted by skratch
i've got 2 o2 sensors from a 2007 roadking that i pulled to install a pciii. i don't need them, so if you want them, they're yours for the cost of postage.
nice, good looking out!
Old Sep 23, 2014 | 04:25 PM
2-Piece's Avatar
2-Piece
Originally Posted by Deuce55
My manual says to reinstall with a new seal washer. Are those special crush washers? Where would I get them? Are they a dealer-only part or pretty common? I assume that I can reuse them for the purpose of this experiment.
If I have to replace the sensor is there an aftermarket option or is that a dealer-only item because they are unique to HD?
I mentioned I replaced the spark plugs and someone asked about what I replaced them with. I went to NAPA and got the Champion equivalent. 2-bucks each. Work fine.
as always, thank you for your help.
They do use a crush washer but I've removed and re-installed lots of them with no issue. Put a little antisieze on the threads if you like.
Pretty sure the factory HD plugs are made by Champion.
Old Sep 23, 2014 | 07:11 PM
Deuce55's Avatar
Deuce55
that is a nice offer. I will take you up on it. Is there a private message capability here to exchange info?
Andy02
Mar 27, 2018 10:30 AM
EJP777
Dec 28, 2017 06:16 PM
GoCards82
Feb 14, 2017 11:05 PM
claytucc3
Aug 9, 2014 12:06 PM
roadking1893
Oct 28, 2010 12:21 PM
