Changing oil
Old Sep 25, 2014 | 07:55 PM
mikeo33y's Avatar
mikeo33y
Originally Posted by soos
I use this with the scoot on the jiffy stand.
i use this too
Old Sep 25, 2014 | 09:38 PM
soos's Avatar
soos
Originally Posted by Spartanden
When you pull the plug, how do you keep from dropping it? I find the oil is too hot to hold the plug. I usually end up dropping in the pan. Do you keep a spare?
The oil drain plug is horizontal in the oil pan so I take it out with a socket on an extension.
Old Sep 25, 2014 | 09:47 PM
Iceman24's Avatar
Iceman24
My process includes:
1. Warm motor
2. Raise bike on lift
3. Attach oil pan (J&S jack option)
4. Put on rubber gloves
5. Pull plug
6. Let oil drain
7. Attach HD oil filter catch
8. Remove filter
9. Pre-load new filter and install
10. Check oil plug (metal)
11. Put new o-ring on plug and install
12. Add new oil to proper level
13. Lower bike
14. Clean-up
15. Ride...
Cheers =8^)
Old Sep 25, 2014 | 09:54 PM
RevBlk's Avatar
RevBlk
I use a tupperware container that slides under the bike no problem. It holds 4 quarts and has a lip on one end for pouring. Don't tell my wife because she's still looking for it.
Old Sep 25, 2014 | 11:21 PM
dochawken's Avatar
dochawken
I use a heavy foil turkey roasting container...bought it for 1$ at WallyWorld about 10 years ago...still going strong. The only issue with it is that it gives the turkey a strange taste at Thanksgiving
crimson13's Avatar
crimson13
+2 same here
Sounds like a good idea
Old Sep 25, 2014 | 11:29 PM
gusotto's Avatar
gusotto
I don't use a lift as it isn't needed. ('07 Ultra.)
I use the Harley drain pan as it's large enough to catch engine, tranny and primary oil in one oil change.
As you loosen the plug, you can tell it's just about to the end of the threads, then grab it with your fingers and yank it out of the way.
There is some heat but not enough to hurt yourself. Place the plug off to the side as it drains.
After it drains, I straddle the bike to an upright position and get a few more drops. It isn't much.
Old Sep 25, 2014 | 11:36 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You just need to get the bike warmed up a bit, not smokin' hot!
Old Sep 26, 2014 | 04:23 AM
grbrown's Avatar
grbrown
Cool
I let it drop into the oil and then fish it out later.
I don't ever run the engine to drain the oils, just leave them for a while to run out. Heating the oil makes it drain quicker, but when I change oils and do other service work I'm not in any hurry! I use an old newspaper to catch any spillage and an ancient enamelled kitchen bowl to catch the rest.
Old Sep 26, 2014 | 06:16 AM
cdestuck's Avatar
cdestuck
Cut a 4" section out of the bottom of a drywall compound bucket. Works for me. Sturdy.
