Clunking when letting off throttle
Old Sep 25, 2014 | 07:08 PM
Roadster's Avatar
Roadster
Default Clunking when letting off throttle
I recently did a trip from Florida to Kentucky driving through the mountains of Tenn. on my 2013 Ultra with 7600 miles I experienced an unusual noise from the primary area. when letting off the throttle or giving it gas I would get a distinctive loud clunk. Shifting appeared normal. Interesting, returning to flat land traffic in Ga. the clunking stopped and the throttle let off was normal and quiet. Stopped at a H.D. dealership on the way home he thought it might be the compensator spring. After returning home to south Florida I spoke with my dealer, he seemed to think it might be the automatic adjustor on the primary. Just curious if anyone else has had this experience. Thanks in advance.
Old Sep 25, 2014 | 07:11 PM
Delzore's Avatar
Delzore
Compensator.. mine does the same thing... if at low rpms, on and off will make a clunking noise in the primary.. I had my dealer open it up last week and they verified all was in order there, everything was tightened to spec... i don't hear it all the time, but yeah, its noticeable if you are in any gear and coasting along at 1500 rpm.. probably should not be lugging things that way though
Old Sep 25, 2014 | 07:28 PM
murph's Avatar
murph
Roadster,
I also live in PSL. I had something similar happen to my 12 SG while in the mountains. HD checked mine and found nothing wrong.
Old Sep 25, 2014 | 11:58 PM
kojak's Avatar
kojak
Compensator. Will go bad eventually, you'll know when it does.
Old Sep 26, 2014 | 02:11 AM
Freebirdsride1's Avatar
Freebirdsride1
On my 2008 ultra the compensator make noise and the dampener pads in the rear sprocket squeak on throttle up and down, loud pipe help.lol
Old Sep 26, 2014 | 06:30 AM
road king Q's Avatar
road king Q
mine makes a noise. Much more noticeable at lower rpms. Hear it good when I am coasting and turn on the cruise. No tach so can't tell you numbers. Service guys rode it and said nothing out of normal.
In discussing it, i did learn more rpms are 'sposed to be better. That's when they told me not to be putting along in 6th at 60 65ish mph. He said 70+ minimum. I have learned my "noise" is less when I run a little higher on the rpms. I cruise the ozark hills most of the time. Lot of accel/decel and few long flats
Old Sep 26, 2014 | 09:51 AM
Bingee's Avatar
Bingee
Try riding in a lower gear. Low rpm's in high gear creates slack in the drive train making the noise. Riding in too low a gear is also hard on the engine.
Old Sep 26, 2014 | 10:22 AM
Lowcountry Joe's Avatar
Lowcountry Joe
The sorry *** cranks in todays Harley motors seem to be most happy at about 3000 rpm. After getting up to speed, riding at less than 2000 rpms (lugging) is just asking for future drive-train and engine issues. You guys without tachs are especially susceptible to lugging since you can't see where your engine if operating.
I ride a lot at 2500, and I try not to let it fall below that when at speed by varying the gear I'm in to compensate for the speed I desire. Rule of thumb: Keep the engine humming along...you will be glad you did.
Old Sep 26, 2014 | 01:59 PM
jinxwolf73's Avatar
jinxwolf73
I also read/discovered this same information and I never drop into 6th gear until I hit 70 -75 mph so this makes sense. right at 70 I am hitting 3000 rpm. Like the other poster mentioned, I try to cruise between 2500-3000 rpm range. Once it starts to drop below 2500 I just don't care for how the bike feels at that point. Just kind of sluggish to me.
AUZ_LFFL
14
Jun 2, 2018 06:13 AM
wadescar
May 23, 2018 02:41 PM
Bedore
Jul 22, 2010 12:35 PM
mikeault
May 31, 2010 02:59 PM
butch63255
Aug 23, 2008 07:44 PM
