Engine Stabilizer
Old Oct 2, 2014 | 07:54 PM
austinslider's Avatar
austinslider
Default Engine Stabilizer
I had my stock engine stabilizer replaced with an Arlen Ness stabilizer this past weekend on my RG. After it was installed, I noticed more vibrating and noise coming from the front end. After coming home from a ride today, the bolt has sheered off. Can I ride my bike with the engine stabilizer not attached? thanks in advance
Old Oct 2, 2014 | 08:02 PM
mkguitar's Avatar
mkguitar
can, but shouldn't..
it'll stress the other parts of the mounting system.
mike
Old Oct 2, 2014 | 08:07 PM
austinslider
That's what I was thinking. I guess I will try to fix it this weekend. Never fails...
Old Oct 2, 2014 | 08:18 PM
SeaZund's Avatar
SeaZund
you kept your original parts, right?
Old Oct 3, 2014 | 03:52 AM
grbrown's Avatar
grbrown
No way! Your engine/trans and rear wheel depend on that stabilizer to keep them straight within the frame. It's a critical part! I can't imagine why yours has broken, they are normally a very sturdy construction.
Old Oct 4, 2014 | 09:06 AM
$tonecold's Avatar
$tonecold
I am running the hole shot stabilizer on my '09. I haven't notice any additional vibration, but I did have the bolts that hold the stabilizer mount to the front head back out (I probably missed torqueing them). I actually did a pretty long ride before I noticed it and I really didn't see any difference in the handling. If I had it to do again I probably wouldn't buy this link because it is not really noticeable once the tank is installed. I wouldn't ride the bike without it, but if it comes loose while you're riding it won't cause any great handling problems. I would compare the new part to the old one to assure that the dimensions are the same. Also make sure you are installing the piece correctly, I seem to remember that it is directional. If everything checks out I would replace the broken bolt, then loosen and re-torque all the connections before riding it to see if you are still experiencing vibration. Good luck.
philellis
Mar 14, 2013 01:43 PM
angelrod
May 17, 2012 03:03 PM
b stard
Ironhead
May 24, 2010 07:41 PM
Just Dave
May 14, 2008 06:24 PM
