Head pipe install question
Old Oct 4, 2014 | 06:40 PM
Mixter's Avatar
Mixter
Default Head pipe install question
When installing a headpipe how do you know if it's seated properly in the outtlets...so there is no exhaust leak? Or does it not matter too much?
Old Oct 4, 2014 | 06:53 PM
ultraclassic53's Avatar
ultraclassic53
I just seated mine in the outlets and made sure everything was lined up then tightned the bolts two turns at a time moving between all 4 bolts so as to torq them down evenly. When I hit Spec I started it up I listened for leaks but I was good
Old Oct 4, 2014 | 06:57 PM
Pitbull2411's Avatar
Pitbull2411
I just use my hand before it gets to hot, or you can put on a glove to feel for air. Some use a flame.
Old Oct 4, 2014 | 07:15 PM
Mixter's Avatar
Mixter
Cool thanks for the tips
Old Oct 4, 2014 | 07:21 PM
103 sedona orange's Avatar
103 sedona orange
Check your manual for proper installation & torque sequence.
Old Oct 4, 2014 | 07:58 PM
TcHunter's Avatar
TcHunter
I know when I installed mine the directions said to start with so many Ft lbs on both bolts then start with the lower bolt for the final torque Ft lbs then move to the top bolt. I am not sure if it matters or not. That was for the Cobra Power Ports.
Zoogie
2014-2024 Touring Models
24
Mar 14, 2015 09:20 PM
Sandcrab
Jan 28, 2015 06:50 PM
rufasim
Nov 15, 2012 09:11 AM
Born2cure
Aug 27, 2012 11:12 PM
TickTock
Nov 6, 2010 03:42 PM
