Just installed the header piipe and the install went well. However it appears that the bolts on the exhaust flanges should go deeper onto the bolts. They are flush with the end of the nut (maybe a single thread beyond). I torqued everything to specifications and used the oem exhaust gaskets. Anyone who has installed these let me know if this is correct?
As long as the nuts are somewhat even on the studs and there are no leaks I would say your good to go.
Probly a good ideal to recheck them after a few heat cycles.
The nuts on mine are about 3/32 to 1/8 past the studs.I also did not use a torque wrench which may be why mine are deeper,however I did not crank them down either.
I am going to check them again using a torque wrench.
An exhaust leak would sound like a ticking noise.
You are good then. Mine are about the same. It's because the flange is different then the stock flange. The stock is designed to go "into" the gasket and the FM head pipe is designed to sit square on the gasket. I have mine torqued fairly tight with a 1/4" drive. I have rechecked them also with no problems. Also, checked for leaks a few times with smoke and also by blocking the exhaust and listening for whistling around the heads.
