Fm 98: Wow!
Decided to go FM based on all the 107 reviews. Pulled everything apart and got it back together. Fired right up. With the addition of the Jackpot slip ons things sounded awesome. Hat's off to FM. Only problem was I had was wicked (I'm from the Boston area
) stumble starting at around 2,000 RPM. Couldn't roll on the throttle without it bucking and skipping. I called FM and got another MAP with more fuel in the lower cells for the PC3 I am running, but, still didn't help. I was afraid that I might have mis-aligned the cam/crank sprockets so I pulled the cam cover and everything was ok. Double checked everything else on re-assembly, but, still stumbled. Went with my gut and started adding fuel in the RPM ranges that I was having issues with. WOW!!! It runs and pulls!!! Still having some issues with pinging in some lower throttle ranges, but, getting better. Hoping FM has a MAP that will get me closer and more accurratley than my ear tuning, but, WOW!! What a massive change. I will more than likely have to get an actual dyno tune to get things spot on, but, I can't wait to get some miles on this motor. Fuel Moto ROCKS!!! Motor is quieter than ever with the hydraulic upgrade and the cams are whisper quiet. Motor has never been this quiet. Pipes sound awesome. Anyone thinking of using anything Fuel Moto I say go for it!! If anyone has a FM 98 upgrade that had a stock ECM, stock headpipes and Jackpot 4" slip ons can you e-mail me your MAP if you are wunning PC3? I would like to see what you have for numbers in various cells. Thanks
Neil
RDMC
Thanks for the suggestion, it may still turn out to be the case. That is why I like to post on this forum, to pull from the experience of other members.
Thanks,
Neil
RDMC
