Throttle by Wire
Old Oct 12, 2014 | 04:37 PM
smithbrl's Avatar
smithbrl
If the throttle grip is tight against the switch housing it can cause it to bind. Try loosening the housing and move it very slightly away from the grip.
Old Oct 12, 2014 | 11:11 PM
GNrider's Avatar
GNrider
I wouldn't wait. Mine went out and left me stranded. Bike would barely idle and no throttle at all.
Old Oct 13, 2014 | 09:16 AM
62hdbiker's Avatar
62hdbiker
I had exact same problem on my 11 ultra limited.
Replaced the throttle (about $130) and fixed problem
Old Oct 14, 2014 | 03:28 PM
Gliden's Avatar
Gliden
Originally Posted by themouth!!!
If you want to replace the stock one, you don't have to run the wires. You can change it by pulling the TGS out of the bar far enough to unplug it from the green connector. 30 minute job max...If you can't do it, head over to Biloxi and I will take care of it.
Yes You can pull it but as I recall you first have to go into the fairing to undo the factory tie rap to get the slack you need to pull it.
If you pull it and it don't come, pull the fairing and go in to free up the slack you need.
Rick48
General Topics/Tech Tips
Mar 27, 2018 01:11 AM
rshwetz
May 15, 2017 03:10 AM
matttaylor817
Jul 7, 2015 04:06 PM
dc3plt
Apr 11, 2015 06:44 PM
conmore
Feb 2, 2012 08:17 PM
