Cams
Old Oct 30, 2014 | 10:31 AM
C.H.L.'s Avatar
C.H.L.
If you get a power vision from FM and use their map - expect about 82 Hp and 100 Tq
If you do a search, you'll find 2 or 3 threads on the 255 cam..... 2 or 3 hundred :-)
Old Oct 30, 2014 | 10:40 AM
2004Sierra's Avatar
2004Sierra
Originally Posted by ke5rbd
The stock heads can only benefit up to .500 lift, beyond that not so much. The 204's are at .508 lift. Most of the bolt ins are at .555 up lift which doesn't make that much difference. Put compression and heads then the .540 up lift makes bunch of difference.
Its true stock heads don't flow better above .500 lift.
The benefit of a .500+ lift cam on a stock head is that the valve will stay at .500+ lift for a longer period, increasing flow and performance.
The flow on my race car heads peak at .600 lift. The custom camshaft designer spec'd a .690 lift cam to keep the valve in peak flow for a longer period for better performance. Pretty much standard practice in performance engines to open valves past cylinder head peak flow rates.
Higher lifts above .500 will increase performance on a stock HD heads.
Old Oct 30, 2014 | 10:58 AM
fwb35's Avatar
fwb35
Increasing the duration will net the same results without increasing lift, increasing lift gives the cam a steeper ramp increasing valvetrain stress, in racing engines they do this because your not building a 100k mile engine, my race engine gets rebuilt after 10 races, the valvetrain takes the most beating so it all gets replaced.
Old Oct 30, 2014 | 02:14 PM
ke5rbd's Avatar
ke5rbd
Originally Posted by bklynbob
The aftermarket usually out does the oem because they don't have the restrictions/ design boundaries. You might like the Andrews 48 or RedShift 527.
I agree on the OEM cams not being as good as the aftermarket. The only cam in the drop in that Harley makes that doesn't fit the restrictions/design boundaries is the SE204 and 211. I know of a 14 SGS with SE204 and Power duals dynoed at 96hp and 114 torque. I know that is exceptionally high numbers. It does compare to the Andrews 48, Feuling 543, Andrews 57, TW 222/555, on a stock head compression engine. The 211 is also good but has a little too much duration to suit me, unless in real light bike with stock heads.
Old Oct 30, 2014 | 03:58 PM
2004Sierra's Avatar
2004Sierra
You are correct. I agree, increasing duration will help with cylinder filling, but at the cost of driveability. Increased duration results in later intake closing (at same LSA). This requires more compression to maintain low end and it moves the power band up.
More lift Does Not require more compression to compensate and will increase torque at given duration because the duration can stay the same with more cylinder filling from the increased lift.
As far as valvatrain durability, the agressiveness of the ramps is up to the cam designer. The total lift number really doesn't tell the agressiveness of the ramp. You have to look at the duration @ .200, .300, .400 .500 lift to see how agressive the ramps are. The ramps can be somewhat mild to very agrressive.
I was discussing lift and duration numbers with a cam designer several years ago and he had a very good analogy. He said the path from the base circle of the cam to the nose of the cam was like a roadmap. Same starting point, same destination, but several different routes to get there.
Obviously the more agressive ramps will make more power at the cost of longetivity. There are always trade-offs in getting more performance. If someone wants a 100,000 mile Harley they better leave it stock. LOL.
Please don't think I'm being argumentative, just a friendly discussion.
Old Oct 30, 2014 | 04:13 PM
OldPhat's Avatar
OldPhat
SE-204 is a good all around cam in a stock 103 HD engine, SE-211 likes more compression in a 103 HD engine.
Old Oct 30, 2014 | 07:45 PM
gregmay's Avatar
gregmay
If you just like to cruise around and like low end torque go for it. It will pull harder on the low end and properly tuned it will run well. Most people hate them but I suspect they haven't ridden a bagger with 255s in it tuned properly.
Remember you don't ride the dyno sheet, other cams will make more power but do you typically shift at higher rpms?
Old Oct 30, 2014 | 07:53 PM
ultraclassic53's Avatar
ultraclassic53
I'll answer the question asked I have ran several 255's in 103's. What you can expect is more low end grunt. It helps a bagger thats loaded down get going. If you ride 2-up your bike will feel more responsive. You can roll on the throttle and not have to down shift. It will fall flat on the top end but the truth is most touring people aren't running up on the top end. You will be able to use 6th gear more often.
Old Oct 31, 2014 | 12:45 AM
ke5rbd's Avatar
ke5rbd
I can agree with most of what you are saying. The part that I question is you didn't say a thing about rpms you are turning to need to rebuild at 10 races. If you are only running .690 lift and had lifters and matched springs with light valve train with good rockers, I am very surprised at having to replace every 10 races unless they were 500 miles long and you were turning 8500 rpms. Not comparing apples to apples as our engines are only turning 5500 to 6000 ever once in a while. Our seat pressure on our valves is around 130# and yours was probably more close to 300#'s. I built and ran drag engines with some .750 to .825 lift cams and +300#'s seat pressure and turned them over 8000 Rpms and they would last all season and then only the valve springs needed replacing. The bikes are only making slightly more than 1 hp per cubic inch and the engines you are talking about is over 2 hp per cubic inch. All I am saying is there are lots of bikes with performance cams running around that last indefinitely as long as they are tuned right and rode and maintained right. IF you run them 6000 rpms everytime you shift no they won't make it and neither would a stock motor.
If running an engine with less than .600 lift and set up right with the right springs and good valves, floating rollers in the lifters, and roller rockers, and keep it cool and maintained and it will last. Will it outlast a stock engine, who knows. I will say I would have lot more fun than I would with a stock engine. If you want to run it completely stock just go right ahead and enjoy doing it. If you want to run performance get the right combination and have fun. If it breaks fix it and don't break it again. I like the sound of a performance engine and knowing the power is there if I want it. Just my contribution to the conversation.
gregsdart
Feb 16, 2018 09:40 AM
Tn.Heritage
Jun 15, 2010 11:50 PM
gmc1999
Nov 20, 2009 07:11 PM
neonhomer
Exhaust System Topics
Sep 2, 2008 08:42 PM
dg7080
Sep 11, 2007 08:12 PM
